Old 10-23-2008, 07:20 PM
vonjet vonjet is offline
Default 40 amp or 60 amp alternator
Hi Everyone,
Im in need of alternator and Im not sure which model my electrical system will require. 40 amp or 60amp.
I have an all electric 12v system. Dual GRT EFIS screens and EIS.
Tru Trak Autopilot, Landing Gear Pump, Flap Motor, Landing LIghts, Nav/Strobe. Garmin 340 Audio, Garmin 327 Transponder, Dual ICOM a200 coms.
I also plan ot use a back up SD-8 alternator.
What main alternator would work for this system?
Bryan
Old 10-23-2008, 07:22 PM
Geico266's Avatar
Geico266 Geico266 is offline
Brian, there is an active thread about this very subject.
http://www.vansairforce.com/communit...ad.php?t=35325
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
Old 10-23-2008, 07:30 PM
mannanj's Avatar
mannanj mannanj is offline
Default Alternator
Originally Posted by vonjet View Post
Hi Everyone,
Bryan
Bryan:
Someone will probably beat me to it, but this has been discussed many times on the forums. Go with the B&C 60 Amp externally regulated. (most expensive but probably the best). Next would be the Plane Power 60Amp.
Learn to use the "Search" feature of these forums which might save you a lot of time, as a lot of knowledge and info are already here just waiting to be re-discovered!!!!!!!!!
LAUS DEO
Mannan J.Thomason, MSGT. USAF (RET)
VAF788
"Bucket List" checkoff in progress!
Old 10-23-2008, 07:31 PM
Default 60 amps it is
Well I dont know my load amount so I think I will just play it safe and go with the 60amp.
Bryan
Old 10-23-2008, 08:15 PM
N941WR's Avatar
N941WR N941WR is offline
Bryan,
The one major advantage to going with the 60 amp alternator is that should you add to your your load, you won't have to upgrade the alternator.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
