Old 10-23-2008, 03:06 PM
Capflyer's Avatar
Capflyer Capflyer is offline
Default The New Aviation Superstore
Well, it looks as though I have found the newest winner in the "my aviation isle is better than yours" in the category non-traditional aviation supply stores. And the winner is Harbour Freight. Unlike their whimpy competitor's aviation isles (Lowes, Home Depot, Sears), look at what Harbour Freight now carries in their aviation isle.
Mike
JAMES AIRCRAFT.com
Flying - RV8 Hot Rod "Drone Killer"
Flying - RV8 "Look'n Good"
RV4 - FAST & FUN! Rebuilt, Flown, Sold
RV-7A Built, Flown, Sold
Old 10-23-2008, 08:53 PM
flytoboat's Avatar
flytoboat flytoboat is offline
Default Harbor Freight
Also check out these items.
ITEM 98262-0VGA
ITEM 98263-0VGA
ITEM 30617-4VGA
Don
VAF #1100, EAA864
-6A bought flying
Old 10-24-2008, 12:57 AM
az_gila's Avatar
az_gila az_gila is offline
Smile Neat....
ITEM 98262-0VGA
ITEM 98263-0VGA
ITEM 30617-4VGA
...but caution, the third item has a 82 degree angle - OK for deburring but not countersinks.
Can anyone confirm if the second item is a 100 degree countersink? It sort of looks like it, but it wasn't in the specs....
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 10-24-2008, 05:45 AM
pierre smith's Avatar
Default If it's Harbor Freight......
......it's probably Chinese
Regards,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 10-24-2008, 06:38 AM
flytoboat's Avatar
Default angles
Gil,
I haven't actually measured the angle, but when my tech counselor visited this Tuesday, we compared HF countersinks (second item) to what came in my Planetools.com kit and agreed they were the same angle. HF countersinks have three flutes, Planetools have two.
Also a note on the dogleg deburing tool: just a little bit of pressure while spinning the tool to debur would force the handle up against the curvature in the dog leg and bind up, stopping rotation. I took a rubber grommet with a hole the size of the shaft and tie wrapped it on the shaft to keep it from binding. Even with that, it doesn't work nearly as nice as the Planetools debur tool.
Don
VAF #1100, EAA864
-6A bought flying
