Originally Posted by bcondrey
I went through this a few months ago with MT. Some of the early models, especially those with B or C suffixes on the serial number, had issues. You send in your governor and they will upgrade it to an "F" level revision which completely solved my problem. At the time I sent mine in the total time it took them in the shop was only a couple of days. I was surprised when I received it back when I saw the list of parts that were replaced on my unit with only 45 hours on it. I was also pleasantly surprised at all aspects of their customer service.
No charge for upgrading to the "F" level revision. Only thing they could do better would be to have a pool of units that they could send out on an exchange basis to minimize down time.
Bob
RV-10 N442PM
After a few hours of flying I had my MT governor upgraded from the -B to the -F version. It definitely solved the aforementioned surging problems at high power settings. 75-ish hours and a year later there are no major problems, however...
The darn thing is still not as precise as I think it should be. For example, in stable cruise flight and in the governing range of the prop, if I pitch up or down ever so slightly to change the airspeed, the prop RPM will change too. About a 10 knot change in airspeed results in about a 50 RPM change in prop speed. That should not happen if the prop is in the middle of the governing range. I also get slightly higher RPM on the first takeoff of the day (cold oil) than I do on subsequent takeoffs (hot oil), with the difference being about 25 RPM.
If I were starting over I would not buy an MT governor due to its sloppiness in control. However, the behavior described above isn't annoying enough for me to junk it and buy the PCU-5000X that I really want.
