Old 10-23-2008, 12:27 PM
dustman dustman is offline
Default oil pressure sender
Question for the gallery. I am installing electric oil pressure transmitter. My question is on the mounting, is it better to mount it directly to the engine or mount it remotely to the firewall. Is vibration an issue with these transmitters? Thanks
Dustman
RV3B
St Marys Georgia
Dues paid 11-11-2011
Old 10-23-2008, 12:31 PM
scard's Avatar
scard scard is offline
Vibration is an issue. It is NOT recommended to mount it to the engine.
Scott Card
CMW E-Lift
Old 10-23-2008, 12:38 PM
Default oil press
Thanks Scottt, I figured that would be the case any suggestions from anyone on a simple branket or manifold to mount it with other than a purchased device?
Dustman
RV3B
St Marys Georgia
Old 10-23-2008, 12:49 PM
gasman gasman is offline
Default NO MANIFOLD NEEDED.....
An ADEL clamp around the sender connected to another ADEL clamp around the motor mount near the upper right corner of the firewall........ worked for me. It also lets the line run with the mount tube and keeps it out of your way......
Do the same with the fuel pressure sender but in the upper left corner...
Old 10-23-2008, 04:27 PM
Rick_A's Avatar
Rick_A Rick_A is offline
Default Van's manifold
The standard Van's manifold works well. I liked the manifold because each "port" has an inlet and 2 outlets. I used one outlet for my EI pressure sensor and the other output to connect a dumb pressure switch connected to an idiot light.
Rick Aronow,
A&P
Flying 7A Slider;
RV-12 SOLD
Highland Village,TX
Old 10-23-2008, 05:49 PM
az_gila's Avatar
az_gila az_gila is offline
Smile Not an RV...
...but this technique is shown here....
....note that some sensors - like the OP one here - only have one terminal, and rely on a ground. The rubber on the Adel clamps sort of ruins this....
It's not clear in the picture, but there is another wire connected to a terminal on the screw that connects the two clamps to-gether. The large clamp is a standard Adel clamp with the rubber portion removed. A 1 7/16 clamp with the rubber removed worked for the VDO Mitchell senders. Spruce did not have a 1 9/16 plain clamp.
The Fuel Pressure sensor here had two terminals and a rubber clamp was OK.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 10-23-2008, 06:08 PM
the_other_dougreeves the_other_dougreeves is offline
On the 912, the transmitter mounts directly on the engine, although some designs do use a firewall-mounted sender. They tend to have a short lifespan. I had one fail in-flight at 200hr, going full-scale high - a very unpleasant experience.
TODR
Doug "The Other Doug Reeves" Reeves
CTSW N621CT - SOLD but not forgotten
Home Bases LBX, BZN
Old 10-24-2008, 01:34 AM
[quote=az_gila;265646]...but this technique is shown here....
QUOTE]
Yes, and thats what I had to figure out........ Pictures to follow.......
