Old 10-23-2008, 08:09 AM
hydroguy2's Avatar
Default DR's GLO RV-7 pic
Doug, nice pic on the front page. Now could you take a few close-ups of the canopy? I would like to see what was done on the front edge(i.e. what's the black strip on the canopy skin?)
I'm not happy with the fit of my canopy and am interested in any and all fixes.
b
Old 10-23-2008, 08:50 AM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
Originally Posted by hydroguy2 View Post
[IMG]
b
That's an easy one... Build a Slider...
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 10-23-2008, 10:19 AM
glfrdug's Avatar
glfrdug glfrdug is offline
Default Great looking 7
I must say that that is one great looking paint scheme and great color combo.
Hats off to the builder and painters!
Nice looking tailwheel too!
Doug
Who's 7 is this....anyone know?
Doug Bell
RV 8 N266WB
Grand Haven, MI
cell 231-239-3621
Bell Tailwheel Fork #1
dbell@americandunesgolfclub.com
Old 10-23-2008, 10:27 AM
Radomir's Avatar
Radomir Radomir is offline
The owner is Randy Utsey from Charlotte.. cant' wait to see it in person.. I believe he's bringing it back home next week..
Radomir
RV-7A sold
Old 10-23-2008, 12:08 PM
N55CU N55CU is offline
Default Canopy seal
Thank's for the compliments! The black rubber is my second attempt to keep out the rain in wet IMC conditions. I originally used a seal that the canopy closed against but the rain came in at the hinge points. I think I will still get some water with this but hopefully not as much.
Randy Utsey
N55CU
Charlotte, N.C.
randy@djdist.com
Old 10-23-2008, 12:41 PM
N941WR's Avatar
N941WR N941WR is offline
Randy,
One of the best things I have ever seen on a tip up is the use of some rip-stop nylon Velcroed in place to forum a rain gutter over the instruments and direct the rain to the sides.
I can't wait to see it in person!
For the rest, as Radomir said, it is a Charlotte based -7 and the builder, Randy Utsey, did a great job. It is equipped for hard IFR. Randy started flying after I did last year (8/5/07 for me) and has well surpassed over 200 hours on it. This plane will see some use!
And yes Doug Bell, that is one of your tail wheels.
Someone mentioned the yellow prop, well Randy painted a lot of the interior parts yellow as well. Things like the brake pedals, batter box, and a lot more. He really did do a nice job.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 10-23-2008, 07:37 PM
drew4161 drew4161 is offline
Randy Utsey
N55CU
Charlotte, N.C.
randy@djdist.com
This has been a vexing problem for me. I ordered a custom 5/16 soft seal from Steele Rubber and sealed the riveted lip with silicon and it seems to have finally done the trick. I flew through light rain for about 20 min and not a drop of water. The only problem is the rubber seal is very soft but it pushes the "lip" of the canopy up about 1/64 in. in the front. It doesn't look as "finished" as I would like but my radios stay dry.
Old 10-24-2008, 04:04 AM
ronschreck's Avatar
ronschreck ronschreck is offline
Hey Randy,
I just noticed your N-number. Looks like "CU" favors Caroline Utsey. Your wife must be very pleased.
Ron Schreck
IAC National Judge
RV-8, "Miss Izzy", 2250 Hours - Sold
VAF 2021 Donor
Old 10-24-2008, 08:01 AM
DanH's Avatar
DanH DanH is offline
I've not built a tip-up 6-7-9, but reading this discussion made me curious about sealing the canopy skin gap. Seems like everybody is chasing the perfect rubber seal, but the automotive world generally avoids depending on rubber for water sealing in door openings, sunroofs, etc. Whenever possible, they use a channel to guide water where they want it; any adjacent rubber is for air sealing. Why not install a drain channel under the canopy gap, so that water is directed down to the longerons and overboard?
Two quick ideas, no dimensions, no details, just thought starters. The first is a glass/epoxy water channel across the gap between the bulkhead and the seal angle. The second is a formed metal strip; the channel is formed with one pass through a bead roller. It would shim the top forward skin up .016"; don't know if you can get away with it.
Dan Horton
RV-8 SS
Barrett IO-390
Old 10-24-2008, 10:09 AM
scard's Avatar
scard scard is online now
The concept of creating a channel might work fine sitting on the ground, but in the air, trucking along at xxx kts, the rain goes most places that the air goes.
Scott Card
CMW E-Lift
