Old 10-22-2008, 05:47 PM
prkaye prkaye is offline
Default hook for meas breakout force
For measuring the nosewheel breakout force, I understand that the fish scale has to be inline with the axis (the bolt through the center of the wheel). But I don't understand how the hook they have you fabricate is supposed to allow you to achieve this. I don't understand how you attach the hook.
The only method I have come up with is to wrap safety wire around the bolt that passes through the wheel, on each side, so that it is held down by the head of the bolt (or the nut on the other side). Does anybody have a photo of how the hook arrangement is supposed to work?
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 10-22-2008, 05:56 PM
Geico266's Avatar
Geico266 Geico266 is offline
I think you are making this more complicated than it is. Just hook the scale to the axle hole & pull. If your scale won't fit use safety wire to make a loop. Go for 28-30 pounds, recheck it after 25-30 hours the first time.
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
Old 10-22-2008, 06:01 PM
Chino Tom's Avatar
Chino Tom Chino Tom is offline
Safety wire is what I used. I removed the wheel pant mounting brackett and
wrapped safety wire around the washer (on the late style wheel pant mount,
it is easy to attach the safety wire around the smaller washer next to the fork). Made a loop in the wire for the scale hook to fasten too. Simple and easy.
Tom Prokop
Chino, CA
RV-8A,180/CS/Carb, AFS 4500 EFIS/EMS
RV-6, sold, 820 hrs of fun.
Old 10-22-2008, 07:07 PM
Just hook the scale to the hole & pull.
What hole? You mean take the wheel off, and use the hole that the bolt goes through? The other holes in hte fork aren't inline with the wheel axis.
Phil
RV9A (SB)
Ottawa, Canada
Old 10-22-2008, 07:14 PM
noelf noelf is offline
I purchased a hardware store bolt (soft) and drilled a hole in the bolt head and also one near the end of the threads. I temporarily replaced the nose wheel AN bolt with the hw store bought one and performed the fish-scale measurement procedure that way.
Old 10-22-2008, 07:34 PM
Default Coat Hanger Wire
I made a "tool" of bent coat hanger wire that I pass through the opening where the tire goes between the forks, latch on itself with a bent end hook, hook the fish scale on the installed wire pull "tool" and pull. Take it off and repeat on the other side. The fist time the breakout force gets low and you let the nose down you will think the tire is blown. "A" pilots have been known to descretely wash there own drawers after the first occurrence. Check and retorque regularly early on because it goes low early in it operational life. Every annual after that has been good enough for me after the first year.
Bob Axsom
Old 10-22-2008, 10:42 PM
yakdriver yakdriver is offline
Take the wheel off and put a hook through the axle hole. This ain't rocket science. Also it is better to tighten it for a couple of pounds extra as it will loosen up a bit the first few hours. We did my friends at about 26lbs as I remember. Don
RV 7 N212MD Flying as of 12/22/2007
Backcountry/TCOW Super Cub flying 03/12/2011
Next project?
Old 10-22-2008, 10:55 PM
mike109g6 mike109g6 is offline
Default breakout
Phil,
Just get a wire coat hanger, elongate the wire that you put your shirt on, take the hook end and from under the fork hook it over the axle. Bend a 90 degree angle under the fork to keep the hook on the axle. Put your fish scale on the elongated wire shirt hanger and pull. Repeat on other side, you'll probably find that right and left differ, split the difference for around 26lbs.
Mike H 9A/8A
Old 10-23-2008, 05:10 AM
pierre smith's Avatar
Default Easier still.......
........is to use a socket on the nut or bolt head with an extension and press against it with a bathroom scale. Have a buddy read it.
Regards,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 10-23-2008, 12:45 PM
cbo111's Avatar
cbo111 cbo111 is offline
Default smart
Man, that is downright brilliant! I spent an hour screwing around with a coat hanger......
Chuck Olsen
RV-7A
TSP
Regards,
