Originally Posted by hevansrv7a
200 times 50 degrees / 360 degrees = 27.7 revolutions per second which is 1667 revolutions per minute.
I did not note the indicated rpm when I took the picture, but that's about right. I think this may be a nice way to quickly check the tach.
Does anyone with more technical knowledge of digital cameras have more information?
There is no need for more information - your calculation is pretty much accurate.
There is a question though: why would you want to go such long way to check your tach? I mean it either works OK, or you can clearly see something is wrong. Tach is simply an impulse counter so in case when:
a) impulses are intermittent (bad wire/sensor) it will 'shake' the needle and you will clearly see it or
b) it counts them wrong, but then it will show a number way off (like x2 or x0.5).
I can't see a situation where it would show just a little bit wrong (like 50rpm all the time) and even if so that probably wouldn't matter in your flying.
