This means....
.....that you should check the wear patterns and flip the tires on the rims when you see an obvious inner wear pattern to extend the life of your tires.
They'll wear much faster on the outside because when you land, they're dangling from the gear, with an even greater angle and slide on the outside portion as you touch down.
Regards,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
