Old 10-20-2008, 02:43 PM
IowaRV9Dreamer's Avatar
IowaRV9Dreamer IowaRV9Dreamer is offline
Default need help locating secondary oil temp port on O-235-L2C
Hi - to all you knowledgable Lycoming experts - is there a place on a Lycoming O-235-L2C to install a secondary oil temperature probe? If so, where? The engine has the Lycoming spin-on filter adapter (which houses the primary probe and the Ventratherm) and is also set up for an oil cooler.
I've looked thru the Lycoming data with no success.
Thanks for any info,
Dave Gribble VAF #232
Building RV-9A N149DG (slider, IO-320, IFR)
Restored and Flying Beech Super III N3698Q
Marion IA
Struggling with fiberglass
There is no sport equal to that which aviators enjoy while being carried through the air on great white wings." Wilbur Wright, 1905
Old 10-21-2008, 08:38 AM
mahlon_r mahlon_r is offline
There really isn't a good place that will give you the same temp reading as the normal oil temp location. Some use a 1/8 pipe style probe on the front end of the lifter galleries but the oil tends to be hotter there, then where you take it normally. The specs you are given are for the standard location which is about the coolest the oil ever is. So if you use a different location, the oil temp is going to be higher then what you would see at the standard location. I suppose, once you get the error factor down from normal use, you could use either place, correcting the front lifter galley location back to standard location specifications.
Good Luck,
Mahlon
?The opinions and information provided in this and all of my posts are hopefully helpful to you. Please use the information provided responsibly and at your own risk."
Old 10-21-2008, 11:49 AM
Default what about this
Thanks Mahlon - I'll check out the front of the engine. What about the location shown below? After reading the Lycoming oil filter adapter information, I think this is just a plug where the ventratherm used to be. I think it has been relocated to the oil filter adapter. Do I have this right?
Thanks for your help
Marion IA
Old 10-22-2008, 07:21 AM
You could use that port; however there is no flow through it when the vernatherm is closed. So it would be relying on convection when the vernatherm was closed. Might indicate the same temp and might not. There was a certified engine installation that used it, with a really long oil temp sensor probe. Never understood how it could be used as a primary location but it was. I never tested to see if there was a delta with the standard location. I suppose if there was a very little leakage past the closed vernatherm, it would have flow past it and that might make it accurate to the standard location.
Good Luck,
Mahlon
