10-20-2008, 10:30 AM
before hanging engine...
Are there any things I should mount on my firewall before hanging the engine? On the one hand access might be easier for some things, but on the other hand I might be guessing at ideal locations.
In my case it's a FP Carb O-320 on a -9A.
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
10-20-2008, 11:03 AM
I put all the battery stuff on, than I put the center thingy on for the firewall. Than I installed the engine mount and engine. than I install the mufflers and left them loose for proper alignment after everything else went on.
10-20-2008, 12:02 PM
things on the firewall
1. brake fluid reservoir
2. fuel sump (optional)
3. battery box
4. oil and fuel pressure transducer manifold
5. cabin heat box
6. oil filter / prop gov recess
7. holes for cables, wires, fittings, etc
Steve
10-20-2008, 12:26 PM
Add to that list..
Master and starter relays
Current Shunts
ANL Fuses if your using them
Put it all the nuplates for the hose clamps for fuel, oil and breather lines.
If your going with a bone stock config and plan to use Van's FWF kit, it comes with plans to detail where to put almost everything. You can order these plans separate.
If you modify the layout, your on your own.
It is easy to add stuff that just requires a hole but of you need to rivet or need clearance, do it before putting the mount on.
I also used nutplates for anything mounted to the firewall so that you do not have to have two people to change out any part.
Before hanging the engine, make sure you put the oil pressure port restrictor fitting in the case. It is hard to impossible to get in after the fact unless you have one of them fancy new engines with a rear facing port and if it does, good luck getting the plug out of it!
10-20-2008, 01:17 PM
To answer the question, fit as much as you can just holding the engine up to the mount with an engine hoist. Check out other RV's to see where they placed things. You can generally figure out most locations and it is much easier to mount stuff without the engine hanging there. It gets pretty tight back there quickly.
Now for the off topic part. I am not a fan of hanging a bunch of stuff on the firewall. Generally speaking, the engine side of the firewall is a pretty harsh environment. Temps are up over 220 dF and the wind howls throughout. My preference is to hang as much on the cabin side as I can. Not only does it extend component life but it makes it easier to maintain the appearance of the engine compartment. I will be the first to admit that it makes it harder to get to sometimes but my airplane has a boot cowl. The RV-9A probably does not so that may be a factor for you. As a point of reference, there are only two things on my firewall, the heat valve and the manifold for the temp/pressure senders. Makes it real easy to clean. YMMV, to each their own, all standard disclaimers apply.
Randy Pflanzer
Greenwood, IN
www.pflanzer-aviation.com
Paid through 2043!
Lund fishing Boat, 2017, GONE FISHING
RV-12 - Completed 2014, Sold
427 Shelby Cobra - Completed 2012, Sold
F1 EVO - partially completed, Sold
F1 Rocket - Completed 2005, Sold
RV-7A - Partially completed, Sold
RV-6 - Completed 2000, Sold
Long-EZ - Completed 1987, Sold
10-20-2008, 01:22 PM
The oil pressure fitting....
.....on the engine. It's impossible to rotate with the engine mounted,
Regards,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
10-20-2008, 01:33 PM
Not exactly what you asked for, but you should attach and safety whatever needs it before you hang the motor. For example, the oil temp sensor is tough to safety wire with the engine on.
Steve Zicree
Fullerton, Ca. w/beautiful 2.5 year old son
RV-4 99% built  and sold
Rag and tube project well under way
paid =VAF= dues through June 2013
10-20-2008, 02:03 PM
Yes to all of the above. I waited on my cables for carb-fi, mixture until the engine was hung and than went with my choice of pass through the firewall.
With a nose wheel you have half the battle won, make sure the plane is level and use a cherry picker hung at the center of the motor, should be a loop for that, may have to push a little and hit the bolt with a rubber malet to get them in, it took me about an hour by myself to get the mounts and bolts put in. They have crazy pins to put in, the best thing to do on that is clip the pin on one side right level with the hole in the bolt to the nut, insert and than take a screw driver and kick the long end over the end of the bolt. I spent about 15 minutes doing that.
10-20-2008, 02:13 PM
Thanks Guys!
Yes, i actually have unpacked my FF kit (not yet inventoried) but haven't opened the plans that came with it.
2 more questions:
1. I have an engine hoist (borrowed) that uses a big hydraulic cylinder. Is it unheard of for these things to "let go" if you leave the engine hanging on them for too long? Would be nice to leave the engine hanging from the mount roughly in place for quite a while before mounting it, so I can move it out of the way when workign on firewall stuff. But i have visions of the hoist giving out and letting my engine crash to the floor. Paranoia?
2. My engine is coming this week, from Aerosport. Will it come with some kind of sling or chains already attached by which to lift it?
Phil
RV9A (SB)
Ottawa, Canada
10-20-2008, 02:22 PM
It should have one of these:
As far as the FWF kit and plans, the only thing I did not do before mounting the engine is cut the control cable holes because I want to make sure thats where I want them first.
I hated my engine hanging on the hoist.... Made me nervous!
