Rob, The balloon method is the best in my opinion.
Use two balloons from the same batch. One on the tank and another separately. All balloons loose some air over time. By using two, you can compare them over several hours. If the one on the tank goes down faster than the separate one, you need to look for a leak.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
