Old 10-19-2008, 12:09 PM
danielhv's Avatar
danielhv danielhv is offline
Default How close is close enough?
Im plumbing the wing... got the top skins clecoed on, and im plumbing it up to matchdrill.... I have a plumb hung on each end of the spar on the bottom side. I have 11/32" from the rear spar to the string on the outboard end, and 13/32" from the rear spar to the string on the inboard end. Is 2/32" acceptable? I have not done anything as far as correcting for twist. These are the numbers "out of the box" so to speak...
Old 10-19-2008, 12:25 PM
Transporter Transporter is offline
Default Fixture Adjustable?
If your wing fixture arms are adjustable a couple of turns on the adjustable arm at one end will zero this out.
Means the difference between zero twist in the wing (the design) and 1/16" twist (what you have now).
Is it a big deal? Maybe not, but at 200 mph any twist is going to result in the airflow acting on the wing in a way that Van didn't intend.
Mike
Mike Dooley
RV hitchhiker
RV8 SB
VAF#1067, EAA Chapter 91
Old 10-19-2008, 12:40 PM
danielhv's Avatar
Mike
will do... it IS adjustable... I just didn't know how carried away I needed to get!
Old 10-19-2008, 05:13 PM
AF_Alan's Avatar
AF_Alan AF_Alan is offline
Default It is 3/32" on the -9
Don't know about the -7 but in the instructions for the -9, it states that 3/32" difference between the ends is acceptable. It is stated to measure it after you cleco the tank on (before drilling, etc.). Sounds like you are good out of the box.
Alan
RV-9A Wings
N984AW Reserved
Old 10-19-2008, 08:34 PM
Hawkeye7A's Avatar
Hawkeye7A Hawkeye7A is offline
Don't forget that the fuel tank skins and the outboard skins are of different thickness. Mine were within 1/32" so I figured "perfect enough". She flies great with no "heavy wing" or any other anomalies. Don't remember who said it, (maybe Jay Pratt; "We're building an airplane, not a watch"!)
--Hawk Pierce
RV-7A Flying as of Sep 7, 2008
Phase One complete as of Nov 16, 2008
Finally painted!
600+ hours and lovin' every minute of it!
N728E
SE AZ
"I fly because it frees my mind from the tyranny of petty things."
--Antoine de Saint Exupery
