Go Back   VAF Forums > RV Firewall Forward Section > Electronic Ignition Systems
  #11
Old 10-27-2008, 05:15 PM
chaskuss chaskuss is offline
Originally Posted by rocketbob View Post
You have a bad pickup sensor. You can get a new one from Electroair or from the original manufacturer, which is Electromotive.
http://www.electromotive-inc.com/sensors.html
part # 250-72212
I carry a spare with me in my tool bag.
James,
As Bob mentions, there was a fair number of failures of the older 3/8" diameter pickup. You might want to consider upgrading to the newer 1/2" diameter pickup (255-72218). You will need to remove the adapter housing to enlarge the hole that the pick up mounts into, to 1/2" diameter. This will allow the use of the newer style pickup.
Charlie Kuss
Old 10-27-2008, 07:17 PM
az_gila's Avatar
az_gila az_gila is offline
Smile ....or I could sell you my unused old style 3/8 pick up...
Originally Posted by chaskuss View Post
James,
Charlie Kuss
....or sell me your old magneto hole adapter housing so I can use it....
Somehow...in a loan to another builder to keep his plane flying and a shipment to Jeff Rose, the housing adapter got lost...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 10-27-2008, 07:23 PM
rocketbob's Avatar
James,
Charlie Kuss
I have a friend that had nothing but trouble with the 1/2" pickup in the magneto housing. After trying 2 of the 1/2" variable reluctance pickups, he machined an adapter and went back to the 3/8" pickup, no problems since.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 11-05-2008, 03:12 PM
PocketRocket PocketRocket is offline
Default Engine rought running
To update you all:
I found that I was low on compression on #1 cylinder and removed it to find that the inlet valve is not seated properly. This seems to have allowed the ignited mixture to penetrate back down the inlet tube, and when the cylinder is under maximum pressure, I think this is going all the way back to the mixture plenum. If it doesn then this could then burn the charge going to the other cylinders - hence the irregluar rough running. When I was switching off the second mag, this must have been lowering the cylinder pressure enough to prevent the mixture burning in the plenum. Does this sound plausible
Thanks for all your replies.
James
G-JSRV
Old 11-06-2008, 01:04 AM
jclark jclark is offline
Originally Posted by PocketRocket View Post
To update you all:
James
G-JSRV
Don't know if this is your problem though it seems to have merit.
After over 1000 hours, our Jeff Rose/ElectroAir system has been running fine. During initial tests, I had some problems and it turned out to be wiring harness issues. Make sure you have good caps on the end. I would get what seemed like a backfire under high load (max power climb tests).
But, since you have had a scope on the system this has probably been ruled out.
James E. Clark
Columbia, SC
RV6 Flying, RV6A Cowling
APRS
