so so
I have been hesitant to enter into this area but......
I bought an Airmap 500 to get an inexpensive GPS that could serve as a backup when I eventually get my "keeper". I know we're talking about the 2000 here, but the software is likely similar if not identical.
I find the Lowrance interface to be very clumsy. Yes, you are using arrow keys to work your way up and down menu selections and it is very "heads down" in operation.
I find that when I haven't used the unit for a while, I have to relearn how to do things again (like build a flight plan). It is not very intuitive. A couple of times I have had to get the manual out to re-figure out how to do something.
Speaking of the manual. It is very limited. There are many undocumented operations in the unit. For example, I have never successfully reversed a flight plan. When I try to do it, the unit simply ignores my menu selection. I then make a new flight plan for the trip home. There is no mention in the manual anywhere about reversing a flight plan.
There are also lots of silly features that clutter up the unit and make it that much more difficult to navigate around. Do we really need an E6B in our GPS?
I would like the ability to turn stuff off/make it go away. There are lots of goofy things I will never use like OBS hold. However, if you stumble into OBS hold, it fundamentally changes the way the moving map works. I simply want that "capability" removed.
That leads me to my one tangible complaint. On 3 occasions(twice in flight, once on the ground) the moving map would not move. It seems to revert to a fixed location and just sit there. The HSI screen still works but the map is dead. No amount of fiddling seems to be able to recover it including rebooting the unit. Did I select something form the menus that I shouldn't have ? Maybe but 99% of the real value of any GPS is in the moving map. If it doesn't move, it's nothing but a distraction.
In summary, I would prefer less "fluff" and more intuitive operation of the core aviation functions. I recognize that other people might think that OBS hold is a good thing for a VFR GPS but I want the ability to disable/remove it. If others want to keep it, that's up to them. Right now, I don't get a choice.
On the plus side, this little unit fits in a shirt pocket and can go 10+ hours on a set of AAs. As a backup, you just turn it on and you know where you are. You can even leave it in your pocket if you like :-). Pretty close to ideal.
