Old 10-16-2008, 06:40 PM
grover grover is offline
Default afterfire on mag check
performed one high speed taxi- - run-up was fine immediately prior. taxi'd back for departure, and did another run-up. when the mag was turned off, the plasma EI did fine. when the EI was cycled off then on, there were a couple of 'pops' in the exhaust. it has never done this before (new engine, has maybe .3 on it), and I'm suspecting it was running a bit rich & warm after the taxi test. anything to be concerned about? mag on left side, P2+ on the right side. FP, carb. 0360.
james kleen
savannah
RV8sp
- RV3
Old 10-17-2008, 04:49 AM
mahlon_r mahlon_r is offline
If it was a da da dull sound, I wouldn't worry to much. That is pretty common with new engines until the rings seat. But if it was loud bang type sound, I would investigate further. Maybe ignition problem but also could be a loose exhaust.
Good Luck,
Mahlon
?The opinions and information provided in this and all of my posts are hopefully helpful to you. Please use the information provided responsibly and at your own risk."
