10-16-2008, 05:19 PM
Drill a wire conduit hole in a closed wing
How does one go about drilling a hole for a wire conduit in a closed wing? I have an RV-8 that I want to add some additional wires to the wing tip and the existing wire hole is too small. Looks to me like I need a long drill bit to enlarge the existing hole. Other ideas? Where would I get such a bit?
Jim Shannon
10-16-2008, 05:30 PM
Jim,
I had to drill a 2nd hole in the ribs for my AOA line after the wing was closed.
To do this I used two drill extensions and a uni-bit. I had to grind down the head of the bit extensions so they would fit through the holes but it worked out.
Granted, it was a pain to re-install the uni-bit and extension as I moved along but it wasn't difficult. Oh, I also used a Pneumatic angle drill to turn the bit when I got into wing.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
10-16-2008, 05:55 PM
I added an aluminum conduit using 1/2 x .035 6061-T6 tube Adel clamped to the ribs at the accessible root, tip and aileron bell crank mid section.
Jim Sharkey
RV6 - finishing up
10-16-2008, 06:26 PM
Bill. how did you get the unibit in the extension? The shank of the unibit is way larger that the hole in the drill extension that I have.
Jim
10-16-2008, 07:20 PM
unibit
I did this with several extensions and bought unibits from Harbor Freight, item 91616-9HZH, for $9.99 and then filled the base down until it fit in the extension. It worked and then I tossed the cheap unibit.
Tom Lewis
RV7a N967BT 1900 hrs.
RV10 N143EB 960 hrs.
Granbury, Tx
http://bit.ly/2bnimsZ
10-16-2008, 07:38 PM
Unibit Extensions
Avery sells extensions in 6" and 12" lengths...they can be combined for additional length. No mod to Unibit required.
http://www.averytools.com/p-533-6-12...xtensions.aspx
Good luck,
Mike
Mike Dooley
RV hitchhiker
RV8 SB
VAF#1067, EAA Chapter 91
10-16-2008, 08:12 PM
Jim
Jim,
My unibit fit the extensions w/o modification to anything other than the extensions.
Tommy's idea of using cheap bits sounds like a good one.
Bill R.
SC86 - Easley, SC
10-16-2008, 09:39 PM
Two pieces of 1/4" threaded rod, two couplers, one drilled/tapped for a setscew. Put unibit in coupler and secure with setscrew. Use one rod and guide into existing small holes with free hand initially, then add second rod as you progress. Use low rpm obviously. Piece of cake.
Mike W
Venice, FL
N164WM
10-17-2008, 09:09 AM
I ground the drive end of my unibits into a hex (they come with only 3 flats) which lets you fit it into a socket. Get a hex-to-square adapter for the drill end, then you can mix and match socket extensions as needed.
Jim Percy
SoCal
FFI Wingman
RV-7A, XP-O-360
10-17-2008, 09:36 AM
Take your unibit to the Electrical tool section of Home Depot and match it's shank to one of the conduit bit extensions they will have there. One of these 36" flexible extension should do the trick.
EAA Technical Counselor #5357
