Spraying is also greatly improved if you by higher grade paint.
The cheaper cans spray in a round pattern, which when moving the can equates to heavy in the middle and light on the edges of each pass. This is fine for small areas or multiple sides of small parts but tough for big areas.
The better quality cans have a nozzle that produces a fanned spray pattern similar to a regular spray gun. Works much better on large areas.
The better valve looks like it has a little tab on the top which you depress to open the valve, instead of pushing the whole valve down on the can.
Scott McDaniels
Hubbard, Oregon
