Redrill or Replace Elevator End Rib and Counterweight?
Has anyone run into this issue? I did not get the E-714 counterweight to E-703 End Rib bolt hole straight while drilling. This misalignment will not allow me in put the washer or the lock nut on the bolt. Can I redrill below or above the original hole? Or am I better off replacing the parts? The E-704 rib is ok.
Dan Schultz
=VAF= Annual Paid Subscriber
VAF #1446
Slow Building - 7A Tipper
