10-15-2008, 05:24 PM
Tip: Bonaco vent line fitting
Just picked up a set of bonaco vent line fittings today. I had already done mine per Van's instructions, but these are just perfect- you know. they're made from the same AN fitting but the screen insert is a major improvement over mine. Also, If you're tired of eating vent and fuel line tubing, trying to get bends right. I highly suggest their brake line kit and any fuel lines. Saved tons of time.
10-16-2008, 06:30 AM
Pictures? Links?
Randy Pflanzer
Greenwood, IN
www.pflanzer-aviation.com
Paid through 2043!
Lund fishing Boat, 2017, GONE FISHING
RV-12 - Completed 2014, Sold
427 Shelby Cobra - Completed 2012, Sold
F1 EVO - partially completed, Sold
F1 Rocket - Completed 2005, Sold
RV-7A - Partially completed, Sold
RV-6 - Completed 2000, Sold
Long-EZ - Completed 1987, Sold
10-16-2008, 06:40 AM
Main page, yesterdays news about 1/2 way down....
10-16-2008, 08:35 AM
This may be a dumb question, but... since the filter is poked up into the body of the fitting, what stops mud daubers from building their homes in the exposed portion of the tube? The fuel vents shown in the plans have screens glued to the exterior face, so there's nowhere for bugs to crawl in. Just wondering.
mcb
Matt Burch
RV-7 (last 90%)
http://www.rv7blog.com
VAF #836
Any opinions expressed in this message are my own and not those of my employer.
10-16-2008, 09:11 AM
Make it part of your preflight to check.
10-16-2008, 09:36 AM
I'm with Matt. Living in "mud dauber" country. They don't need depth to build.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
10-16-2008, 10:19 AM
Count me in, I was thinking the same thing.
A dab of pro-seal, stick the screen on the end of the vent. When it dries, cut off the extra screen with a razor blade. Not a big deal and the price was right. Well it was right after Torque the wonder dog ran through the screen from the deck to the kitchen. But then that left me enough screen to cover the fresh air vents.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
10-16-2008, 10:54 AM
I just got off the phone with a gentleman at Bonaco about this, the way they machine and set the screen, the depth between the topmost point of the 45 cut (the way it will be mounted in the bottom of the wing) to the screen is 0.350", and they are unable to reduce that distance.
He suggested, and I agree with, using a cap to fit over the vent (just like a pitot cover) with a "Remove Before Flight" streamer.
10-16-2008, 12:30 PM
Alternatively interlink the 2 vents so that if one is blocked it will suck air to either tank.
EJ
RV7 flying
xp360, CS, All Glass cockpit
10-16-2008, 12:35 PM
Super Moderator
I also "T'd" into the vent line in the cockpit with a one way check valve, such that if the vent is iced over or blocked by mud daubers, it will draw air from the cockpit.
Vic
 Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES
Kitplanes "Unairworthy" monthly feature
EAA Sport Aviation "Checkpoints" column
EAA Homebuilt Council Chair/member EAA BOD
Author "Pre-Buy Guide for Amateur-Built Aircraft"
www.Baselegaviation.com
