10-15-2008, 01:23 PM
Engine Fallout
The time has come to select and purchase an engine for my RV-4 project.
Used Lyco engines for experimentals seem grossly over-priced in comparison with new XP?s and other clones. However given the state of the world economy, I imagine that all of these engines will be in massive over-supply in the coming year with prices falling sharply.
Given that a new Lyco? still costs more than an average family car .... Is a really big price correction in the pipeline ?
I am leaning towards an injected IO-320, the question is new or used and when to buy ?
Any advice appreciated.
Nic
10-15-2008, 02:27 PM
Do prices ever come down ?
It's a small market to begin with. I suspect they would just scale back production to keep prices up. I'd be curious if Lyc prices have ever come down.
On a similar vein, anybody noticed that the price of home heating oil and auto-gas are both down about $1.30/gallon from the peak ? Avgas hasn't budged.
I'm betting that the prices of engines will continue up because they can..... :-(
John
10-15-2008, 02:42 PM
Unlike auto-gas, a lot of the aviation gas people charge you for what is in their tanks. Our AP is $1 higher than another 7 miles away. it is cheaper to fly the seven miles (or at least, a good excuse).
When the tank is refilled, expect to see a new price.
Check out Van's for the experimental Lycoming price. At Sun N fun and Osh, they had a deal (ended up being $500 off and free shipping).
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
Reason: corrected spelling
10-15-2008, 03:17 PM
VAF Moderator / Line Boy
While I am also outraged at Avgas prices, I have to say that one of our local airports is doing as well as they can....their Avgas price has dropped over a dollar since the peak (now $4.23 or something like that).
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
10-15-2008, 03:28 PM
If you are uncertain about prices for engines and fuel, the consensus seems to be to get an IO-360 with "normal" compression and electronic ignition. That will allow you to burn auto fuel (if you can find some reliably that has no alcohol) or even pure alcohol if you adjust the injector settings.
The extra horsepower comes at virtually no price or weight or size penalty. Use a Cato (fixed) or MT or Whirlwind (C/S) prop designed for the RV to avoid any RPM restrictions. I think there may be a Hartzell that has also eliminated the restrictions - just check to be sure. Be happy.
10-15-2008, 03:43 PM
Actually there is a significant size penalty on the -4. The cowl is a very tight fit near the left rocker covers. It will fit, but just barely. If I had it to do again, I would consider a 320 just for this reason.
Steve Zicree
Fullerton, Ca. w/beautiful 2.5 year old son
RV-4 99% built  and sold
Rag and tube project well under way
paid =VAF= dues through June 2013
10-15-2008, 03:50 PM
Senior Curmudgeon
If I was in the market
For an engine right now, I would check this out.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
10-15-2008, 05:59 PM
I am surprised that engine is not sold already.
10-15-2008, 06:08 PM
What do you mean by "normal" compression on the IO-360? Note that an IO-360-A engine has 8.7:1 compression ratio, while O-360-A engines have 8.5:1.
And are you referring to the angle-valve IO-360-A series engines, or the parallel-valve IO-360-B and -M series engines?
10-15-2008, 10:09 PM
Our airpark wholesale...
...quote (for a tanker load - about 8500 gallons) Tuesday night dropped about 20 cents from a week ago, and is 35 cents down from 2 weeks ago.
Depending on how fast your local FBO can empty his tanks, you should start seeing some significant price drops soon when his next batch of 100LL arrives...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
