Old 10-13-2008, 10:32 PM
AX-O's Avatar
AX-O AX-O is offline
Angry Don?t do what I just did!
Guys I thought I would let you know what happened to me so it does not happen to you. I just spent about 3 hours in the garage bolting my 4-inch prop extension on an O320. It all started fine, read the directions, used a 9/16 wrench to get the 3/8 bolts hand tight, then it went down hill from there. I did not have the proper socket/torque wrench combination. Every single combination would not fit. I went to Home Depot and bought a different torque wrench and socket. I torqued everything down per directions. First 10 lbs, then 20 lbs, 30 lbs and finally 35ft/lbs. I then proceeded to make the perfect safety wire job. 6 bolts, 3 wires. I did them about 8 times. Looks nice, job well done. Now let me put the alternator belt on. Nope, $%^&*. It does not fit. Hope that does not happen to you.
Question, do I need to change the bolts or can I re-use them. They were new.
Axel
RV-4 fastback thread and Pics
VAF 2020 paid VAF 704
Old 10-13-2008, 11:33 PM
gasman gasman is offline
Yes, you can use the bolts. But you will have to start off with new safety wire. Don't forget the backing plate.
Old 10-14-2008, 03:21 AM
tinman tinman is offline
Sort of like putting the back wheel of a bike on without the chain...I am ashamed to admit how many times I did this as a kid...
Don Alexander
RV-8 Finished After 8 1/2 Years (2496 hours) of Loving Labor
Summerville, SC
Old 10-14-2008, 09:41 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Axel, just think of the first time as a practice run
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
