Originally Posted by carl nank
As for bolt length...I am having trouble visualizing what you are describing. I am using a Sen. Fixed Pitch metal prop and the Sen. spinner option + Van's prop spacer. When I put a prop bolt through all of that hardware, the exposed bolt threads are long enough to completely engage the the prop flange threaded insert.
Actually I was talking about the length of the bushing the bolt threads into and the length of the bushing and the amount the bushing goes into the prop hub. My prop bushing only goes into the prop hub about 1/8" and the prop hub could take another 1/4".
It may be different with a fixed pitch prop since I have a constant speed prop.
...is the exposed part of the bushing.
This Lycoming SI details the bushing lengths....
http://www.lycoming.textron.com/supp...fs/SI1098G.pdf
....and you have to subtract the prop flange thinckness and the flywheel thickness (0.250 inch IIRC) from the bushing length given at the end of the SI.
This can be a big problem if a spinner bulkhead is also included in the stack up mentioned above, reducing the dimension to around 0.080, and some of that amount is reduced further by the bevel at the end of the bushing.
If you want more "drive" dimension, then you can replace the two shorter bushings with ones longer than the other four... or make them all longer like an O-360-A4A
gil A -
just put two longer bushings on my Tiger per a prop STC option...
