Originally Posted by rwarre
Starting work on the speghetti(wiring). I have a used KT76a with tray and connector. I don't have a clue about hooking up the wires that are used with the connector. I have the pin out diagram but I think I must need an installation manuel. HELP? Randy
The pin out should be good enough in this case...
http://www.aeroelectric.com/Installa...6A-76C-78A.pdf
Power - Ground
14 volts to pin 11, no connect to pin 12
Ground to pin 1 and pin A
Data lines A1-A4, B1-B4, C1-C4, D4
Just connect to the corresponding pins on your altitude encoder.
Panel lights
Pin 3 to ground, pin 2 to your panel light dimmer output
Leave pins 9, 10 , F with no connection.
Interestingly, there is no switched power for the alt. encoder, so you will have to power that up seperately from your avionics bus.
Hope this helps....
