10-13-2008, 09:40 AM
It doesn't matter
Originally Posted by chaskuss
Mel,
I have to ask you why quenching them in water is bad?. I learned this method (water quenching) 30 years ago from a Triumph motorcycle repair manual. It does not make them brittle in my experience. What is the disadvantage of water quenching?
I have found it advantageous to anneal all copper washers or head gaskets (motorcycles) prior to use. These parts get work hardened at the edges, during their manufacture.
Charlie Kuss
Actually it doesn't matter if you let them air cool or quench them in water.
They will still be soft. If you don't believe me..try it. I have.
You can test the "softness" by twisting them like you where trying to bend a penny.
I quench them in water because the scale boils off and they become nice and pretty. And you can install them sooner
Mark
Mark Burns
Ruston, Louisiana
RV-7A N781CM 1,650+ hrs
FFI FL-24
A&P
Reason: duplicate words
10-13-2008, 09:52 AM
Maybe this topic needs another qualifier in that you may not "feel" the difference in the small copper washer, but it is basic metallurgy in that the structure of the material is very different given different cooling speeds. This is what annealing in this application is about. Creating a "loose" structure. You need to look at the material samples under a microscope to truly appreciate the effect of heat application, its rise rate, and cool rate on different metals. Most of them generally act the same and copper is not an exception. It is just a little more forgiving in process.
Scott Card
CMW E-Lift
10-13-2008, 09:54 AM
Quenching Copper
Originally Posted by Mel
The purpose of annealing the washers is to soften them so that they will "crush" and seal. If you quench them in cold water the material will become more brittle and may not seal properly.
Take 2 pieces of steel. Heat them both. Allow one to cool slowly and quench the other one. Put them both in a vise and bend them. You will find that the annealed one, the one that cooled slowly, will bend much further than the quenched one before breaking.
Mel,
OK, I see the issue now. Copper does not have the same properties as steel or aluminum. For steel and aluminum, you are correct, you should not quench them. However, you can quench copper. It's actually the recommended procedure. You don't have to believe me. Try it for yourself.
Charlie Kuss
10-13-2008, 10:02 AM
Quenching Copper
You can test the "softness" by by twisting them like you where trying to bend a penny.
Mark
Mark,
Thanks for the explanation. I suspected that was the case, as obviously letting the washers cool in ambient air has worked for Mel. I'm not a metallurgy engineer, but generally, I find that the repair manuals will state the preferred method. I tried to Google this, but could not find an answer from a "definitive" expert.
I replied to Mel prior to reading your comments.
Can anyone direct me to a definitive answer? I'm not trying to start a "pissing contest". Now I'm simply curious as to what the engineers say.
Charlie Kuss
Reason: added question
10-13-2008, 10:31 AM
Quenching copper in cold water certainly makes it softer than air cooling if you've worked this material extensively.
People can try it if they don't believe it as another poster said. Copper does not behave like most other metals in this regard.
10-13-2008, 10:39 AM
The object is to soften the copper. So how about this? Test the methods: take 2 used gaskets, heat each to red hot, quench one and let the other cool slowly. Mark with a Sharpie so you can keep track of them. Put them in a vise against each other, offset rather than perfectly aligned, squeeze them down and see which one indents the other.
Richard Scott
RV-9A Fuselage
1941 Interstate Cadet
10-13-2008, 10:46 AM
........... could not find an answer from a "definitive" expert.
Charlie Kuss
Charlie, this info from the world of Bonsai(!) might help. Steve.
PS Not sure who is a definitive expert.
PPS This was great thrread drift away from the first question in post #1!
10-13-2008, 01:32 PM
I been quenching
for 30 years and it always seemed to be softer than if i didn't have any water...or there wasn't a handy tree for cover..
Frank
10-13-2008, 01:42 PM
It would appear from this information that it really doesn't matter how you cool copper.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
