Old 10-11-2008, 09:19 AM
mlwynn mlwynn is offline
Default CAT, SCAT, CEET, SCEET
Hi all,
I am working on my FWF installation. I have read Aircraft Spruce's summary of the differences between the abolve flexible ducting. What I can't figure out is, what should I use for my heat muff to cabin duct, blast tubes, etc. So, is it a choice of black over red? I assume that the CEET and SCEET, which are two ply thick, is overkill for the short RV runs. So it comes down to CAT vs SCAT.
Thoughts?
Regards,
Michael Wynn
Old 10-11-2008, 10:09 AM
az_gila's Avatar
az_gila az_gila is offline
Exclamation SCAT is the stuff...
...to use forward of the firewall. This is pretty standard in certified planes.
The 500F rating vs. the 300F rating of CAT is the deciding factor.
Inside the cockpit area, then CAT is OK.
My RV vent kit came from Vans with black tubing still containing the label from the aviation department of JC Whitney....
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 10-11-2008, 11:10 AM
N941WR's Avatar
N941WR N941WR is offline
Originally Posted by az_gila View Post
...Inside the cockpit area, then CAT is OK.
I found some stuff at the local auto parts store that is "custom made" for Van's RV's, just read the label:
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 10-11-2008, 11:31 AM
jferraro17's Avatar
jferraro17 jferraro17 is offline
Opulence, I has it...
Talking
Bill-
LOL!
Joe Ferraro
DFW, VAF #17
SOLD
Old 10-11-2008, 02:28 PM
osxuser's Avatar
osxuser osxuser is offline
Please don't use Cat for anything. After a few years moisture gets trapped between the tubing and the aluminum (Any aluminum it touches) which starts corrosion between that and the steel spring that is in the tubing. I wouldn't consider using anything that isn't Silicone embedded (the S is Scat).
RV4 wing in Jig @ KPOC
RV7 emp built
Old 10-11-2008, 10:47 PM
Default Scat it is
Thanks for the insights
Michael Wynn
RV 8 FWF
San Ramon, CA
Old 10-12-2008, 01:01 AM
az_gila's Avatar
Question Confused...
...about your comments....
Assuming a low temp application, SCAT tubing also has exposed steel wires on it's interior surface, so why wouldn't it corrode in the circumstances you mention above? If anything, the silicone would hold moisture in more efficiently....
SCAT tubing showing exposed wire....
I believe the silicone embedding (the "S") is in the cloth, not the wire....
Gil Alexander
Old 10-12-2008, 04:07 AM
carguy614's Avatar
carguy614 carguy614 is offline
Default copper coating
Gil..
The wire used inside of the SCAT tube is copper coated, just like MIG welding wire, and resists corrosion. It is also a nicer product to use for the air vents. I have used the vinyl wire stuff on auto applications a few times and was amazed at how quickly it deteriorated. for the couple of extra bucks it costs to install SCAT, I think it is a good idea.
2 cents,
Chris
Chris Schmitt
Shallotte, NC
RV9A 90970 N614RV
Sold to nice folks in Texas and badly missed.
RV9 in progress
Old 10-12-2008, 10:31 AM
az_gila's Avatar
Question But... are we comparing...
Originally Posted by carguy614 View Post
Gil..
2 cents,
Chris
....SCAT to CAT like the original post said, or are we comparing SCAT to JC Whitney stuff? - which is a vastly different proposition....
What is the wire compostition/plating of real CAT hose, which oxuser did not like to use? Most likely, it is the same as the SCAT tubing, but I can't verify...
Perhaps oxuser really meant to say "don't use the automotive stuff", which has nothing to do with silicone content....
Gil Alexander
Old 10-13-2008, 04:37 AM
carguy614's Avatar
Default scat
That's probably right Gil. I may not be comparing apples to apples...
Regards,
Chris
Chris Schmitt
Shallotte, NC
RV9A 90970 N614RV
RV9 in progress
