Originally Posted by Brian Vickers
Kelly Aerospace MZ-4222 starter; I mounted the starter that came with my engine core and noticed the gear is resting on the flywheel. See photo. This doesn't seem right(?). Isn't an aircraft starter the same as a car? The gear is only engaged when the starter is activated? The starter is in very nice condition and looks almost new.
Also, while turning the flywheel I noticed the ring gear slips. In fact, I can wiggle it off. I don't see a mechanical fastener. Is this supposed to by a tight press fit?
The ring gear very definitely is a press fit. It probably is the wrong ring gear for that fly wheel. They do not slide on and off unless the parts are heated and frozen appropriately. I can't remember which is which but I've done it and when temps return to normal, the ring gear is attached very tight.
Info on the starter for your particular engine can be found at
http://www.kellyaerospace.com/
The starter gear is probably extended by the drive and should retract when spun up after start. Make sure its gear matches the ring cogs, either 122 or 149.
