Old 10-08-2008, 08:40 AM
Brambo Brambo is offline
Question Gretz Pitot Tube
Starting to button up the left wing and with that install the (unheated) Pitot tube. The instructions do a good job describing how to install the mast and tube, but say nothing about how to join the copper tube from the pitot to the plastic hose I plan to run through the wing. Is there a special connector? My initial thought is to use a compression fitting. Also found that the quick connect fittings that come with the kit will fit the copper tube, but I'm not sure that's a good idea or not. Obviously I want to avoid any air leaks.
Bill Rambo
RV-7A Flying
Old 10-08-2008, 02:09 PM
carguy614's Avatar
carguy614 carguy614 is offline
Default pitot connection
If your pitot line is 3/16 like the Dynon, you should be able to heat and slip the nylon line right over the outside of the tube. super tight seal, and simple.
Normally I would search out the trick connector parts, but this worked real well for me.
Hope this helps,
Chris
Chris Schmitt
Shallotte, NC
RV9A 90970 N614RV
Sold to nice folks in Texas and badly missed.
RV9 in progress
Old 10-08-2008, 02:42 PM
N941WR's Avatar
N941WR N941WR is offline
Hope this helps,
Chris
Chris as some very good advice. I tried using an AN fitting and quick connector but they leaked like crazy so it was all replaced with some tubing.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 10-08-2008, 03:23 PM
Sounds like a great idea, unfortunately the Gretz copper tube is 1/4", same as the tubing. I saw where someone else used a short piece of tubing with a 1/4" ID and a couple of hose clamps. Seems simple enough and should be air-tight.
Bill Rambo
RV-7A Flying
