10-07-2008, 10:37 AM
Newbee question about attaching the wings
Please forgive me if this question has been asked by other newbs, and it's probably a goofy one, but I'll ask anyway...
I've been reading a lot of the other builders' blogs out there, and it seems they always go through this big, long, convoluted process of stringing plumb bobs/drawing lines on the floor/rigging up fancy laser levels/standing on their heads/praying to the RV gods/etc. when it comes to attaching the wings to the fuse. Now, I'm being lazy 'cause I haven't read ahead in the preview plans (so flame me  ), but I thought all these kits were pre-punched, including the location of the bolts connecting the center section to the spars. So what's the purpose of all this measuring and leveling if the bolt holes are already there? Or are they? If so, shouldn't it be just a matter of lining up the holes and sticking the bolts in? Somebody please educate a poor, nubly, newb.
Thanks.
Jeremy Fields
RV-7A (workin' on the tail  )
Fort Worth, TX
jfields77@yahoo.com
241-686-5503
10-07-2008, 10:42 AM
Wings are pre-drilled. However, there are other attach points such as the bracket on that the rear wing spar goes into that has to be drilled and this allows you to make minor adjustments to ensure the wings are plumb and square.
Read on!!
Webb Willmott
Jackson, MS
N32WW
10-07-2008, 10:44 AM
The main spars flex and with just a little force at the tip you can move the location of the rear spar attach point very easily. The RV-10 attach point on the rear spar is already drilled so you don't have to do all this.
Todd
N110TD
RV-10 Vesta V8 LS2/BMA EFIS/One formerly flying at 3J1 Hobbs stopped at 150 hours
Savannah, GA and Ridgeland, SC
10-07-2008, 10:54 AM
There are three possible "degrees" of freedom, as I see it: wing dihedral, twist along the wing's longitudinal axis, and fore/aft movement of the wing tip wrt to the attach point. Is this correct? Which of these do you have control over when attaching the wings? It seems overwhelming to think of how one could control all of these possible directions of movement while attaching the wings and get it to be perfectly symmetric b/n both sides. I've been dwelling on this (not sure why, considering it's a task that's easily a year or two away for me), but I'm already dreading it...
Thanks for the replies.
Jeremy Fields
Fort Worth, TX
jfields77@yahoo.com
241-686-5503
10-07-2008, 10:56 AM
Jeremy, If you want a straight airplane you to will spend a LOT of time with plumb bobs, levels and lasers. One thing about digital levels is they are not exactly precise. I would set my wings up with a digital level and then come back with a machinist level and the rear spar attach would be off almost 3/16" between sides. I spent around 20 hours setting my wings and tail up perfectly before I drilled the holes. I was rewarded with an airplane that flys absolutely straight with no trim tabs. Don
RV 7 N212MD Flying as of 12/22/2007
Backcountry/TCOW Super Cub flying 03/12/2011
Next project?
10-07-2008, 12:00 PM
Dihedral is set with the predrilled center section. Twist, sweep and incidence are up to you.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
10-07-2008, 12:19 PM
Does anybody have a picture?
I'm a visual kinda guy. Maybe if I saw what exactly is being attached to what and what's being drilled to what, it would become more clear. Right now we're about as clear as proseal
Jeremy Fields
Fort Worth, TX
jfields77@yahoo.com
241-686-5503
10-07-2008, 12:29 PM
Only two things really....
.....to be concerned with and they're really no-brainers. As Mel said, dihedral is done for you. Forward/aft sweep is easily taken care of with four plumb bobs made from string and 4 nuts tied on.....two per wing. Tape them on to wing, near the leading edge and drop 'em near the floor and you and a buddy pull a string across all 4 and see if there's sweep.
With the airplane levelled on jacks in both axes, we used a builder's transit to get the incidence set and rear spars drilled. Leave the transit in the same position for both wings....really simple to do correctly. BTW, you'd be surprised at how many RV's are out there flying hands-off level that had the incidence set using Van's simple method of a small block of wood and a bubble level.
Regards,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Reason: spelling
10-07-2008, 12:32 PM
how far is denton from 52F?
as a visual person it'd probably be beneficial to go LOOK at some of the RV's that live there.
i can't remember off the top of my head, but i think there's one currently in progress there...... if not there's a bunch of friendlies over there that i'm sure would be glad to show you around and explain it
Ian
RV-8 economically on hold... short term hold.
AME2, USN
10-07-2008, 12:39 PM
I'm only 10 or 15 mi's from 52F; Hicks isn't too far away either. Guess I should take Jay Pratt up on his invite and go over there and poke around in his hangar. I might learn something and not have to ask silly questions on here  ...
Thanks again for all the replies.
Jeremy Fields
Fort Worth, TX
jfields77@yahoo.com
241-686-5503
