Old 10-07-2008, 10:07 AM
Jim P's Avatar
Jim P Jim P is offline
Default Shaping Clay
For the intersection fairings, what' the best method for shaping clay for F/G layups? What's worked for everyone? I've used pre-made upper and lower, but find that I need to do some additional fairing with clay/ F/G to get the fairings to match the gear leg fairings.
Jim Piavis
RV-7 (Flying!)
http://adap.com/rv7
Redmond, WA
Old 10-07-2008, 12:00 PM
Randy Hooper Randy Hooper is offline
Default Tin Can Lid
Learned from Sam James: Cut the end from a tin can, cutting from the side. This leaves the bead on the lid. Start scraping. By using the proper size can, you will end up with a nice desired radius in your clay.
Randy Hooper
Old 10-07-2008, 12:29 PM
Transporter Transporter is offline
Default Can Lids, etc.
As stated above, find can lids that give you the radius you want:
2 lb coffee can works well for the outer radius, and a soup can works well for the inner radius.
A large (2-3") screw-type radiator clamp also makes a great adjustable scraper.
Mike
Mike Dooley
RV hitchhiker
RV8 SB
VAF#1067, EAA Chapter 91
Old 10-07-2008, 01:03 PM
TSwezey TSwezey is offline
They have some light weight modeling clay at Wal-mart. My daughter is an art student and she used that to do some of the shaping on my fuselage. She shaped it and I covered it with glass.
Todd
N110TD
RV-10 Vesta V8 LS2/BMA EFIS/One formerly flying at 3J1 Hobbs stopped at 150 hours
Savannah, GA and Ridgeland, SC
