View Poll Results: Have you ever had a leak?
Yes, during leak testing 23 29.87%
Yes, after they were on the aircraft 30 38.96%
No, I'm a proseal Jedi knight 28 36.36%
Multiple Choice Poll. Voters: 77. You may not vote on this poll
Old 10-06-2008, 09:06 PM
joeboisselle joeboisselle is offline
Default Have your fuel tanks leaked?
Another thread I started about fuel tank repair/building in respect to the lack of leaking brought up the question of how many people have actually had leaks. And I'm talking any leak, during testing or flying. I did find the pole taken 2 years ago, but there's been quite a few more added to the fleet, and to the forums. Seems like the majority of leaks are the rear baffle, mine have been the outer ribs. What have you all seen?
You can select both yes answers if they apply.
Joe Boisselle
2010 RV-4
1941 Luscombe 8C
Old 10-07-2008, 06:08 AM
pierre smith's Avatar
Default Float sending unit.
....We used the rubber gasket at first and then eliminated it for the repair. That was two years ago....no more leaks.
Regards,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 10-07-2008, 08:24 AM
Paul Eastham's Avatar
Paul Eastham Paul Eastham is offline
During testing I found a large leak at the back corner baffle/rib joint, right where the manual said I would have problems. Using a long stick, I was able to apply more sealant through the filler hole to seal it up.
I also had leaks from the screws at the inspection panel/sender -- I didn't proseal them before testing, in case I had to open up the tank. So much for that plan.
Second tank went better, making sure to put a lot of sealant in those baffle corners.
No leaks after 100 hours flying.
Paul Eastham - Mountain View CA
RV-9A standard build, flying! ~300 hrs
EAA Chapter 338 San Jose
Old 10-07-2008, 09:42 AM
kentb's Avatar
kentb kentb is offline
Default I voted twice...
I had a small leak (soap bubble test) at the skin/back plate. I fixed it with loctite. Two years latter I have a couple of rivets that are starting to show blue. This will be my winter project.
Kent
Kent Byerley
RV9A N94KJ - IO320, CS, tipup
AFS 3500, TT AP, FLYING....
Canby, Or
Old 10-14-2008, 06:31 AM
DaX's Avatar
DaX DaX is offline
Regards,
Pierre,
So I should just ditch the rubber gasket that came with my float-type sensors and use only proseal? I had planned on ditching the cork gaskets, but wasn't sure about ditching the rubber gaskets for the sensors.
http://flyingtodhunter.livejournal.com
RV-7 Wings, Tail, & Tools FOR SALE
Old 10-14-2008, 08:10 AM
Martin Sutter Martin Sutter is offline
Super Moderator
Two leaks in my 7A quick build tanks. The right one had a leak large enough to form a small stream from the bottom of the inboard tank rib the first time I put fuel in the tanks. The left one developed a seep in a bottom rivet of the third rib (from the root) after 2 years of flying. They claim the tanks are tested after assembly but somebody slept when these were assembled. No leaks ever on my RV6 tanks I built back in 1989 after 2200 hrs of flying.
Martin Sutter
building and flying RV's since 1988
Old 10-14-2008, 09:10 AM
cytoxin's Avatar
cytoxin cytoxin is offline
Originally Posted by DaX View Post
Pierre,
not pierre but,
yes. the screws are almost too short for installation of the rubber seals anyway.
William Weesner/ still kicking.
Old 10-14-2008, 07:04 PM
jmbrwn's Avatar
jmbrwn jmbrwn is offline
I did not use the rubber gaskets either and just finished testing both my tanks today with no leaks!!! I really took my time and applied all techniques advised on this forum. Not necessarily a pleasant experience...but definitely a learning one.
Jim Brown
RV6, Christen Eagle II(Sold)
ATP, CFII, A-IGI, A&P/IA
Carrollton, GA
Lyon?s Landing
Old 10-15-2008, 07:36 AM
DaX's Avatar
DaX DaX is offline
Thanks guys.
