O-320-B2A fly before you buy FOR Sale
I am selling the O-320-B2A 160h.p. off of my RV-6. This is a certified engine and comes with the following parts
Carb., Alternator,. Engine mount and gearlegs., 2 slick mags and harness, mech. fuel pump, vacuum pump. baffling for type S cowl, 2.25" prop ext, starter ring gear with inertia ring.
this engine has 2126hrs total time
645 since top overhaul
890 since major overhaul
compresion all in the mid to high 70's
I have all of the original log books, This engine has a hollow crank and spare drive pad for a constant speed prop. it is set up for a fixed prop now. This engine is a conical (straight) mount.
Come fly this engine befor you buy it.
First $10500 buys it!
Great engine for you -6,-7,-9
Serious parties only
Call 317-201-8517
Jon Hubbell
RV-6 Flying IO-320X tip up 500+hrs G3X 2004 Oshkosh Outstanding workmanship award, 2004 Sun N Fun Best Workmanship 2006 Sun N Fun Outstanding Aircraft
RV-10 Flying IO-540-C4B5X 500+hrs G3X 2011 Bronze Lindy Award Winner
"Negative Ghostrider the pattern is full"
