Old 10-05-2008, 02:35 PM
n468ac's Avatar
n468ac n468ac is offline
Default Panel upgrade the third weekend...
http://www.checca.net/n468ac_panel_panelupgrade3.htm
Ok ... it doesn't look like a lot of work.
But we got about 24 man hours in it this weekend ... switching out the breakers from the main panel with the new correct sizes. Sunday was taken up with mounting the two overlays.
We both had other things to do ... as my wife said she wasn't going to let the grass go another weekend ... wow i though i might be cutting hay.
If your asking what?s left...
four antennas (nav, com, gps, marker)
8 wires need to be pinned back into the original harness
move one of our extra 12v sockets
add panel mounted push-to-talk on the passenger side
connect in four new breakers
mount the two compasses
(This post by: Christopher Checca EAA Lifetime Member #799388)
Allen Checca (father)
Christopher Checca (son)
RV-6A - N468AC
ENGINE: Lycoming 180 HP O-360-A1A
PROPELLER: Senisentch 72FM859-1-85
WEIGHT: Empty Aircraft 1152 lbs
BASED: KC09 - Morris, IL.
Flying since June 6, 2005
N468AC Web Site
