Old 10-05-2008, 01:19 PM
lucaperazzolli's Avatar
lucaperazzolli lucaperazzolli is offline
Default drilling the right holes into the canopy & frame. What a confusion !
I drilled all the canopy into the frame of my RV8, everythings went well.
But now :
- plans say to enlarge the holes in the canopy with a plexi drill bit to #27.
I saw in the forum that a lot of builders do this with a 5/32 unibit.
I can order a #27 plexi drill bit or let's go for a larger 5/32 drill bit ?
A larger hole can help future cracking ?
What's better in your experience ?
Thanks in advance
Luke
Trento, northern Italy
RV-8 QuickBuild, Catto 3 blade Prop, YO-360-A1A. Status : I-LUKE is Flying - 400 h. and counting
http://www.rv8.it
CrewRV8 team leader
https://youtu.be/VhAkhuqZMQA
https://www.youtube.com/watch?v=he9AFHRO1OY
=VAF= 2020
Old 10-05-2008, 06:51 PM
N53LW N53LW is offline
Default #27 plastic bit
Use the plastic bit, the unibit may grab & crack the plexi when enlarging. The purpose of the over size hole is to prevent cracking when you pull the pop rivets. The rivet will exspand when pulled. Be sure to use the correct pop rivet for the plexi, which is the AACQ 4-4 aluminum ring shank, " I believe". Check your plans.
Old 10-06-2008, 08:52 PM
rvbuilder2002's Avatar
Actually Unibits work great in acrylic. The cutting action is basically the same as that of a plexi bit only it is able to make larger holes.
Scott McDaniels
Hubbard, Oregon
Old 10-13-2008, 10:55 AM
Default hope help someone
Well,
I drilled the bow of the canopy frame with #30 and canopy #27 plexi drill bit (averytools);
I drilled the other holes into the canopy with #5/32 plexi drill bit.
Gus agree !
ciao
Luke
http://www.rv8.it
CrewRV8 team leader
=VAF= 2020
