Old 10-03-2008, 12:35 PM
Brian Vickers Brian Vickers is offline
Default Monitoring bus voltage vs. alternator voltage (?)
I like warning lights and alarms that tell me when something is malfunctioning. My Plane Power alternator installation diagram shows a simple alternator out light alternative. Aeroelectric Figure Z-11 shows the use of a low voltage monitor module. I purchased the unit and it actually has an over voltage alarm limit as well. My understanding is that the Plane Power system monitors only the alternator. The B&C unit is connected to the bus and therefore monitors bus voltage. Does this mean when the alternator voltage drops, the B&C unit will not be activated until the battery is depleted below the monitor's preset limit? In other words, the warning light will not trip while the battery is fully charged. I want to know the moment the alternator goes above or below normal operating limits.
Brian Vickers
Bainbridge Island, WA
RV4
Old 10-03-2008, 12:41 PM
vic syracuse vic syracuse is offline
Super Moderator
Brian, I have the B&C regulator with the built-in low voltage warning, and it is just that---- it comes on when bus voltage is below about 12.3-12.5 volts, which usually means the alternator has failed. That usually happens within a couple of seconds of an alternator failure with a typical load. In flight I usually show a steady state current of 18-25 amps in the daytime, so the battery will quickly drop to 12.5 or less rather quickly once the alternator is offline.
Vic
Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES
Kitplanes "Unairworthy" monthly feature
EAA Sport Aviation "Checkpoints" column
EAA Homebuilt Council Chair/member EAA BOD
Author "Pre-Buy Guide for Amateur-Built Aircraft"
www.Baselegaviation.com
