Old 10-03-2008, 08:45 AM
Epsound Epsound is offline
Default Buying a tool set or piecing one together????
Hello all,
I've been looking at the list of tools recommended by the Vans site for RV7s. I already own about half of what is on the list. So, I was thinking that I would use the list to complete the missing pieces. Wouldn't this be cheaper? I would be very grateful for input as to whether this list is complete? I do want to get a belt sander, band saw, and drill press. However, what else would you any of you recommend (if at all) adding or subtracting from the list. I would like to ward off the infamous incremental trips to the hardware store for that 'one little thing'. I do love the hardware stores. But I also like to stay in the ?groove? when on a project. Below is the list at Vans.
Appreciate any suggestions.
Cheers
Recommended Tools for the RV-3,4,7,8,9,10
2X and 3X Rivet Gun , or 3X Rivet Gun Only **
E-Z Change Spring
Air Swivel Regulator
1" Dia. Flush Set **
3/32" Cupped Set 3.5"
1/8" Cupped Set 3.5" **
3/16" Cupped Set 3.5" (only for fabricating spar)
Double Offset Cupped Set
Mini Bucking Bar 1 lb. **
Anvil Bucking Bar 1.9 lb.
Footed Bucking Bar 2.2 lb.
Microstop Countersink Unit **
#40 Countersink - 3/32" Rivet **
#30 Countersink - 1/8" Rivet
#8 Countersink - #8 Screw
#10 Countersink - #10 Screw
Wiss Snips Left & Straight **
Wiss Snips Right & Straight **
Air Drill
#40 Drill Bits (for 3/32" rivets) **
#30 Drill Bits (for 1/8" rivets) **
#19 Drill Bit
#12 Drill Bit
12" #40 Drill Bit
12" #30 Drill Bit
Deburr Tool **
Cleco Pliers **
4 Cleco Clamps -1/2" Jaws
4 Cleco Clamps -1" Jaws
Pop Rivet Tool **
2 Screwdriver Bits - Size #2
Hand Squeezer / 3" Yoke
1/8" Universal Cupped Set
3/16" Universal Cupped Set
Flat Set 1/2" x 1/8" ** (**2 required)
Flat Set 3/8" x 1/8"
3/32" Rivet Dimple Die **
1/8" Rivet Dimple Die
#8 ScrewDimple Die
24" Stainless Rule
Unibit 1/4" - 3/4" by 1/16 ths
Permanent Markers ** ("Sharpie" Xtra or Ulta Fine Point)
3M Cut & Polishing Wheel 6"
Hearing Protector
Safety Glasses
325 Cleco Fastners - 3/32" ** (** 30 required)
175 Cleco Fastners - 1/8" ** (** 10 required)
Deburring Set - Large Holes
Edge Deburring Bit
Fluting Pliers
Rivet Cutter
Air Tool Oil
File Card / Brush
10" Vixen File
C-Frame Riveting Tool
Optional Tools
#6 Countersink - #6 Screw
Drill Stop Set of 4
Angle Drill Attachment
Cordless Screwdriver (for deburring)
Threaded Drill Set 6 pc.
Back Rivet Set **
Dimple Die Organizer
Removable Rivet Tape
Tape Dispenser
12 oz. Dead Blow Hammer
Recommended Tools for the RV-12
Old 10-03-2008, 09:26 AM
JHines JHines is offline
From an absolute perspective, the cheapest route is to obtain every single item individually from a variety of sources. That's a lot of work.
The common aircraft tool vendors will usually let you make substantial additions and subtractions from their prepackaged kits and still give you a good discount.
Some items on the list are overpriced from a tool store, such as:
sharpie markers (buy at office supply)
tape dispenser (office supply)
die organizer (cut up a plastic cutting board and drill holes in it)
I'd recommend the DRDT-2 dimpling tool instead of a C-frame tool (quiet, consistent, much less chance of making accidental holes).
Many people do not use any deburr tools at all, just a combination of files/sanders/scotchbrite wheels & pads.
Jonathan Hines
Charlotte, NC
Old 10-03-2008, 10:46 AM
Default Thanks Jonathon
I won't be ordering my tail kit for a while. In the mean time, I plan to put the tools together slowly. It should keep me occupied until I can order the first kit.
I was just looking at some 'Ryoby' tools i.e. 9" drill press, belt sander, and 9" band saw. Could get all three for around $350.
Thanks for the tip on the DRDT-2 dimpling tool.
Evans.
Old 10-03-2008, 03:53 PM
xavierm xavierm is offline
Evans.
I ended up buying a tool kit, however, before I bought the tool kit, I bought many tools from various sources.
If you check eBay regularly, you can find great deals (I bought pneumatic squeezers, yokes, seamer, drills, micro stop cages, nitrile gloves, and bulk drill bits from eBay, just to name a few). Be careful though. Check with several sources before buying stuff from eBay. Know what you are shopping for. eBay prices for some items are higher than some of the online retailers.
I also have the Ryobi press, belt sander, grinder, and band saw. They all work great for me. Get a metal blade for the saw.
I added the following to my kit (by buying from other sources)
2 pneumatic drills (for a total of 3). I have one with a #30 bit, one with #40 bit and one with a rivet removal tool (drill and tool came from eBay, just never took it off the drill). My "quick change" chuck is grabbing the other drill.
Pneumatic squeezer. (I have two, with two different yokes.)
Rivet gun (again, two, one with a cupped set and other other flat)
DRDT (love it)
Torque Wrench
Back Rivet plate
Skill ixo screwdriver for deburring (Carefully)
Cheap "hobby" drill press. I keep a light deburring wheel attached to it. It's so cheap, it drills oblong holes.
I at least doubled the amount of clecos. I have about 900 silver and 400 copper.
I also bought about 20 side grip clamps.
_____________
Xavier
RV-7 build in progress
www.theaviatorx.com
"Genius is persistence in disguise"
Old 10-03-2008, 06:08 PM
RickWoodall's Avatar
RickWoodall RickWoodall is offline
Default Time is money
I wanted to piece the tools together, started the list.... got frustrated.
A few folks suggested calling avery. I did and got their kit, upgraded with x3 gun and pneumatic squeezer. Other than some extra 30 and 40 bits, and one more deburring tool there is nothing i needed until the canopy. I bought the glass drill bits and the glass edge tool. Everything else little that i needed, small files, odds and ends i got at the local hardware store. I hate cheap **** and have been 100% happy. Your time and effort deserve good tools. If you buy an avery set and treat them well you will get 75% of your investment back if you cash out. Thats a fair deal in my book.
Order quality and get building.
Rick Woodall C-GSTT "ghost"
9a -TMX io-320, catto three blade, dual dynon hdx with a/p. 900+ hrs in 8 yrs flying.
Flew to Osh 11,12,15,17,19. SNF 2013. West to Cali /Washington/Vancouver/crossed the Rockies north to Red Deer east to Moosonee and over to maritimes. South to Jekyll Isl, cedar key, and Key West etc. 6 trips and 17 islands of the Bahamas. Flown turtles and dogs for Pilots n Paws too. Love our Rv's
Old 10-03-2008, 06:30 PM
N941WR's Avatar
N941WR N941WR is offline
LOL!
Double or triple that quantity! You can never have too many clecos!
Also, you will continue to buy tools throughout the build. Heck, you will also find yourself buying new tools after it is flying.
One additional item that I found VERY helpful is this Tight Fit Drill Kit. There are better ones out there but this will get you through one or two airplanes.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 10-03-2008, 08:10 PM
AF_Alan's Avatar
AF_Alan AF_Alan is offline
Default HF can be your friend
I compared the tool lists from Avery, Cleavland, and Van's to get an idea of what were must haves and various prices. Then watched Ebay and got a good start. Garage sales for band saw, drill press and compressor ($230 total). Bought DRDT-2 head and buddy welded a frame to save ~$100 and shipping costs.
Harbor Freight was good for bench grinder, air die grinder, snips, misc files, and pneumatic parts. Don't go cheap (HF) on the torque wrench.
I found a Mill file from Sears makes nicer finish than the vixen or deburring tools. Bench sander from Lowes and I was through the 1st wing before needed more tools...37? tube flaring tool.
Ditto to add more clecos for the slow build.
Alan
N984AW Reserved
-9A Wings
Old 10-04-2008, 12:54 AM
Hawkeye7A's Avatar
Hawkeye7A Hawkeye7A is offline
Default Avery's tops!
I bought a "kit" from Avery minus the items I already had on hand, which was considerable as I was machinist in a previous life. But the savings was SUBSTANTIAL! One thing I picked up on a "reposessed" close-out and wouldn't dream of being without is a pneumatic rivet squeezer. Even at full price it's one of the most valued tools you will own. Not just for squeezing rivets but just dimpling the wing ribs after you have them assembled will knock the time down by 1/2 to 2/3. Just be sure you have the male die inserted into the hole before you hit the lever. (Ask me how I know. No, don't, it's embarrassing) Mel once told me that he completely dimpled his plane with a hand pop rivet tool. You'll know when you shake his hand! Now that's some perseverance! But it's all a part of the building process.
--Hawk Pierce
RV-7A Flying as of Sep 7, 2008
Phase One complete as of Nov 16, 2008
Finally painted!
600+ hours and lovin' every minute of it!
N728E
SE AZ
"I fly because it frees my mind from the tyranny of petty things."
--Antoine de Saint Exupery
Old 10-04-2008, 09:49 AM
Rupester Rupester is offline
I pieced together my own tool kit. By looking thru the catalog lists of five or so suppliers, it became clear that prices on individual items vary a LOT. Since I was waiting for my tailkit, I had the time to check prices and "cherry pick". When I went back and looked at what I got compared to the pre-assembled toolkits, I saved about $250 ... which I actually spent on a Cleaveland Main Squeeze, one of the better decisions I made.
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
Old 10-05-2008, 07:03 AM
rzbill's Avatar
rzbill rzbill is offline
Default Take your time if the first kit is a ways off
If you are not ordering the tail kit soon, take your time and piece together your tools.
I prodominantly used e-bay. It was either 2 or 3 purchases. I spent well less than a new kit and wound up with WAY more useful parts and tools. For instance: Multiple air-drills, lifetime supply of bits, drill stops, stacks of bucking bars, every size and shape of rivet and dimple set, and a few tools (such as strap duplicators) that I have not used yet. The list is much longer. I think when it was all done, I ordered a backrivet set brand new from Avery. It also saved me enough money to justify the DRDT-2.
You can skip the band saw and put more money into a better drill press. Be concerned about the SLOWEST speed the press will turn. Get as far under 500 RPM (common on cheapo's) as you can find. In regard to a band saw, I really think it is an overrated luxury item. Anyone with reasonable hacksaw skill can make equivalent or better pieces by hand and there are not that many parts that require this type of fabrication. The belt sander will be handy, but again, the same work can be done via hacksaw, file and scotchbrite wheel in a reasonable amount of time. Think about your shop space, the addition of these two tools, and the floor space required for them.
Bill Pendergrass
ME/AE '82
