warning - check your "Slime Fighter" oil water separator
There is a recent post on the So Cal RV list describing an emergency landing by an RV pilot due to smoke in the cabin. All ok, but cause was determined to be the lack of welded joints on the "Slime Fighter" oil water separator that had recently been installed. Note: not poor welding - no welds at all. Apparently it had only been epoxied together.
If you have purchased this product, you may want to inspect it closely, especially if it was a recent purchase.
regards
erich
