Old 10-01-2008, 04:58 PM
prkaye prkaye is offline
Default axle hubs... as per attached drawing??
On page 10-6 of the plans it says "then insert the U-623-1 axle hubs into the bearings as per the attached drawing.". Huh? I don't see any drawing attached to anything in the vicinity. I guess they mean Drawing C1, but I don't see how that's "attached" to anything in particular.
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 10-01-2008, 08:33 PM
FrankK90989 FrankK90989 is offline
Yes for $10 Van's sells sets of detailed "attached" drawings, but only to builders in Minnesota!--Just kidding.
Them are just the mushrooms they slide into the bearings.
while your at it you might want to consider staking them to the 630 fork and making a center spacer so you can torque the axle bolt tight and have the wheel turn freely.
http://www.vansairforce.com/communit...ghlight=spacer
See this thread.
Frank Karasti
Hibbing, Mn
RV-9A
Flying--------->-
