Originally Posted by RV6_flyer
Comments:
Need a question answered for my comments.
Is there an oil pressure switch for the HOBBS?
If there is NO oil pressure switch on the hobbs, I would move the HOBBS/VOLTMETER fuse to the Essential Bus. IF there is a Hobbs Oil Pressure Switch, I would move the Voltmeter to the Essential Bus. It really does not matter IMHO if the hobbs runs during an emergency so it would not matter if the circuit was moved to the Essential Bus. I also like to have the 12V accessory power outlet (what you call a 12V Cig Lighter) hot off the battery. If it is only used for a backup GPS, then place it on the Essential Bus. Why two voltmeters? I see one on the Essential Bus and one on the E-Bus.
Move Engine Instruments to the Essential Bus.
Like someone else said, Do you really need all those lights on the E-Bus? Ask yourself the question: What will happen if I leave them on for over a week between flying sessions?
One suggestion I have on the Strobe light circuit. (Wish I would have done this.) Do not put the Strobe Lights on a switch. Use a PULL type Circuit Breaker instead. This will then act as an alarm as you walk away from the airplane with the master on. IF you are ever working on the airplane with power, just pull the breaker.
I would increase the wire gauge on the Nav/Com to 18 AWG. May need 18 AWG on the Transponder and stobe lights depending on how far the run is. Could start getting too much voltage drop on the smaller gauge wire. I would recommend 12 AWG on the accessory power and E-Bus. Maybe overkill but you may make changes that need it later.
You may get lots of comments on electrical systems that differ from me.
Gary,
thanks for reviewing the electrical system. I took the RV building first class that Dan Checkoway and you over 2 years ago.
The Hobbs meter is not connected to a pressure sensor. It is the GT-50 (g-meter, clock, timer, voltmeter). The instructions say to hook up the red wire to the battery. That is why the GT-50 is connected to the main Batt bus. The green wire should be connected to the instrument power source or master switch.
I will move the 12V Cig lighter to the Batt bus. The GPS will have it?s own source of power.
The Voltmeter on the essential bus should not be there. I did not catch it.
Will move the engine instruments to the Essential bus.
I will look into moving some of the light off the Batt bus.
Good Idea regarding the C/B.
Will change the wire size as well.
Once again thanks. That is the type of info I was looking for.
