Old 09-28-2008, 03:15 PM
JimB JimB is offline
Default Leaky Fuel Tank
Hi Guys, My fuel tank leaks so now I need to cut an inspection hole to get in there and fix it. Whats the best way to cut a hole large enough for this? Nibbler followed by a file is what I'm thinking but would like to hear any better ideas. THanks...........Jim
Old 09-28-2008, 05:31 PM
Mel's Avatar
Mel Mel is offline
We use a 3" hole saw.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 09-28-2008, 06:28 PM
Geico266's Avatar
Geico266 Geico266 is offline
Have you tried to fix the leaks? I'm an expert!
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
Old 09-28-2008, 07:49 PM
Mel, I'll try that first, I just assumed that it would not be big enough to get in.
Old 09-28-2008, 07:50 PM
Larry is there a way to fix a leak from the outside?
Old 09-28-2008, 08:04 PM
Geico266's Avatar
Yes, do a search. There are several ways to fix it. Try that first before you take the tank off and cut a hole in it.
The easiest one to try first is using Green (wicking) LocTite with a small vacuum being pulled on the tank.
Is it on the bottom or top?
Old 09-29-2008, 07:43 AM
Larry, it's not installed yet. Still building my wings. The leaks are in the aft corners. The one one the inside I can get to thru the access panel but one of the outside corners leaks also. I also have a small leak where the skin meets the rear baffle near the center. I'll look for some green loctite and give it a try............Thanks
Old 09-29-2008, 08:57 AM
Geico266's Avatar
You need to hire the neighborhood 8 year old kid with little arms & hands and goop some more pro-seal in there!
Is it illegal to shanghai / force kids into helping build airplanes? I may have stumbled onto something here! Child labor sweat shops building RV's!
Old 09-29-2008, 09:31 AM
flyboykelly's Avatar
flyboykelly flyboykelly is offline
during the construction of my tank I opted to install an end rib access hole on both sides of the tank for that very reason, But before you cut holes in your tank I would try the locktite trick. It seems to work just fine.
Flying as of 1-12-2016!!!!!
Old 09-29-2008, 09:49 AM
Sid Lambert Sid Lambert is offline
You can reach the outboard rib from the filler. Just used a long brush with thinned Proseal on it.
Sid Lambert
RV-7 Sold
RV-4 - Flying - O-320 Fixed Pitch - Red over Yellow
