Need to touque the impulse coupling mag.
Thanks for the reply Larry,
Yes the 4370 mag has a tapered shaft with a key and tourqing is stright forward.
However, the 4373 with the inpulse coupler has a stright shaft with no key.
The gear is keyed to the top of the coupler and when you try to tighten the nut, the shaft will turn and you can feel the spring tension inside the coupler.
I'm not sure how to hold the shaft to get the nut tightened.
Gary Shelley
RV8, SARL Race 81
Hutto, Texas
