09-27-2008, 02:12 PM
alternate source for engine mounts
anyone know of source for engine mounts other than Van's?
09-27-2008, 11:04 PM
The engine MOUNT is built to match the airframe, what is wrong with Van's mount? Or are you talking about the MOUNT?
09-28-2008, 12:42 AM
Mounts or Mounts?
We seem to have a semantics problem here. Are you talking about the welded tube mount that bolts to the firewall or the rubber "engine vibration mounts" as Van's calls them? The rubber mounts are available from a number of sources, try Aircraft Spruce for a start, but be careful that you know what you are looking for, conical or dynafocal and the engine/airframe combination.
John Clark
RV8 N18U "Sunshine"
KSBA
09-28-2008, 06:24 AM
Sky Geek
Hi Tikicarver,
You might also try www.SkyGeek.com. They had the best prices on Lord mounts, IIRC.
Regards,
/\/elson
RV-7A Tip-Up
NW Austin, TX
09-28-2008, 01:04 PM
Not talking about engine vibration isolators.
I'm talking about the steel tube engine mount.
09-29-2008, 09:24 AM
Oh why ya not say so
Why did you not say so.  Short answer is NO.
There are people that make mounts for Rotary, V6's and Subaru engines but not an alternate manufacuter of Lyc RV steel firewall mounts I know of.
Can I ask why? Van's is about as cheap as it gets and makes good stuff. Do you think it needs improving?
Cheers and welcome aboard, I see you are new to the group. George
George
Raleigh, NC Area
RV-4, RV-7, ATP, CFII, MEI, 737/757/767
2020 Dues Paid
09-29-2008, 09:31 AM
Incidentally,
.....a friend is swapping out his 4 cyl subie for a new Lycoming and had to buy a new motor mount AND gear legs since they're drilled as a unit for his -7. If you want to use the old legs, I found out, you can send them back to Van's to match drill the holes in the new mount. It also depends on the year of gear leg manufacture, whether they have numbers or letters stamped on top.
Regards,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
10-20-2008, 04:42 PM
Kosola
Try http://www.kosola.com/main.htm
On the right of the page, see Products, select engine Mounts and Parts, then Homebuilt. They don't mention Van's explicitely, but I'm sure they can help.
Very good service, good prices, nice to work with. I had them rebuild an engine mount for a Cessna and send it to France, they made it easy and saved us difficult times trying to get the same service here.
Hope this helps
Daniel Mouly
VAF #778 - [2013 payment done]
RV-9A Emp. & Wings 95%, Fuse 70%
Austin Healey 3000 MKIII fully restored
LFCD (Andernos Les Bains), France
Construction Log comments in French (not really up to date, sorry)
