F-713 Aux Longeron and Gear Leg Holes
I can't quite tell from the plans/drawings how the F-713 aux longerons should fit. It looks like they should fit right up against the aft side of the firewall at the front end? At the rear end, it looks like it should match up with the front flange of the main spar (or the front of the webbing?). What is causing me caution here is that the directions say to file the rear of the longerons to match up with the main spar. It doesn't say whether that should be the flange or web of the spar. In either case, I either don't have to file at all, or I have to do much more than file. If I'm to liine it up with the flange, I have to cut off about 1/2".
Regarding cutting the gear leg holes in the bottom skin, I traced the full-sized template from the plans onto a transparency (so I know the transparency is exactly the same as the template). However, when I place the transparency on the bottom skin, there is a rather significant difference between the template and the skin. From the 1st row of rivet holes to the 2nd row, there is 1/16" difference between the template and the actual bottom skin. Between the 1st row of rivet holes and the brake hole, there is an 1/8" difference. Did you guys find the same thing? How did you resolve this?
As always, thanks!
Rich and Cindy Macrafic
Rochester, MN
Flying
