Old 09-27-2008, 04:06 AM
Webb's Avatar
Webb Webb is offline
Default Exterior Fuel Tank
I know this comes up from time to time but here's another angle.
If you look at the Van's performance differences between a 7 and 7A for a 180hp engine, it is 2 mph.
Using the same logic, if you built a belly pod tank, shaped like a wheel fairing, would you only lose 2 mph? Put 2 on, you lose 4mph.
Is this crazy ideal even doable? (What about it Frank?)
Buy 2 main wheel fairings (maybe 1 depending on what the volume is). Do the additional glass work to baffle and reinforce. Mount them upside down under the belly (or the wing). Make removable. Cost is $270 for 1
Or is this just another crazy experimenter's idealistic wish for longer range?
Webb Willmott
Jackson, MS
N32WW
Old 09-27-2008, 04:30 AM
sjhurlbut sjhurlbut is offline
A wheel pant size tank will give you less than 2 Gal extra.
I have ability to carry a baggage compartment tank (16.8 Gal) and a passenger seat tank (60 Gal).
Steve
7A Flying
Old 09-27-2008, 07:29 AM
Ron Lee's Avatar
Ron Lee Ron Lee is offline
Doesn't someone sell a tank for the wing or wingtip?
Old 09-27-2008, 07:58 AM
RV8RIVETER's Avatar
RV8RIVETER RV8RIVETER is offline
Mike Arnold sell a video that shows how he made a cargo pod that bolts to the wing tie down. Looks really cool. I bought the video and am thinking about building one, but shape it like a bomb, to go with the WW2 fighter scheme.
He has the plug so I guess you could contact him and see if he sells them. Or get the video and build it yourself.
http://www.ar-5.com/vidkit96.html Tape 4.
Wade Lively
-8, Flying!
N100WL
IO-360A3B6D, WW 200RV
Old 09-27-2008, 09:04 AM
Webb's Avatar
Steve
7A Flying
Only 2 gallons? I filled up the leaf blower today and the 1 gallon jug is TINY. 1 cubic foot is about 7.5 gallons so I was guessing the quantity would be a bit higher than 2 gallons.
Go with same premise. Use the pressure recovery design for the fuel tank, just a bigger.
Webb Willmott
Jackson, MS
N32WW
Old 09-27-2008, 02:59 PM
dpansier's Avatar
dpansier dpansier is offline
Default Sam James Wheel Pant Capacity
I haven?t drilled or cut the wheel opening in my Sam James pants yet so I measured the capacity by filling with water.
Surprisingly one wheel pant will hold 7.61 gallons.
I weighted the water on a postal scale, came in at 63.4 lbs.
Don Pansier
Green Bay, WI (GRB)
RV-7 N450DP
W9LYX
Antennas for Experimental Aircraft
www.deltapopaviation.com
Old 09-27-2008, 06:58 PM
SportAvServ SportAvServ is offline
Default Wheel pants for tanks
Does anyone have RV-10 pants they could fill and check what they hold?, I would bet over 10gal.
RT
Old 09-27-2008, 09:29 PM
Webb's Avatar
Default For reference
A cubic foot is about 7.5 gallons. A gallon of water weighs about 8.3 pounds.
Calculate on!!
Webb Willmott
Jackson, MS
N32WW
Old 09-27-2008, 10:28 PM
gasman gasman is offline
Calculate on!!
A gallon of gas weighs 6 pounds........... so why would you carry water?...
Old 09-27-2008, 10:32 PM
Steve
7A Flying
THAT'S OVER 1800 POUNDS WITHOUT YOU!!
