Old 09-25-2008, 08:14 AM
sonny junell's Avatar
sonny junell sonny junell is offline
Default I Dented the skin Now What? ? ? Please Help
Ok guys the build is going well enough, however the other day when riveting the elevator skins oops . . . well you can probably figure out what happened, I dinged the skin pretty bad. So now what?
How do I fix it? Bondo , micro bubbles , throw the shizz away and start over .
But seriously what are my options? I thought I would start here first.
- Can anyone recommend a good reference source, book, video, website - Product!
I know there has probably been a thread just like this started and I am sorry, but I searched the forum and all I came up with was blah, blah, blaaaaa
Time, patience, and perseverance overcomes all obstacles.
Our Kit log
www.westernsheetmetal.com
Old 09-25-2008, 08:32 AM
rph142's Avatar
rph142 rph142 is offline
Default superfil
I dented my rudder when i was using the c frame dimpler. The fix was some SuperFil from wicks aircraft. Be sure to rough up the surface with some 180 or 220 grit sandpaper before applying it. Use a rubbery foam sanding block until you have the patch job perfectly smooth.
Rob Holmes
www.myrv3.com
N59LG
The minimum number of planes one should own is one. The correct number is n+1, where n is the number of planes currently owned. This equation may also be re-written as s-1, where s is the number of planes owned that would result in separation from your partner.
- Veluminati
Old 09-25-2008, 08:55 AM
Low Pass's Avatar
Low Pass Low Pass is offline
I have no idea how bad "bad" is, but unless you're planning a polished aluminum finish, just plan on fill and sand.
But stay away from the Bondo. There are some better materials - and easier to sand - out there. I used micro balloons and epoxy resin quite a bit. Just make sure you have a good anchor pattern and it's clean before applying.
Bryan
Houston
Old 09-25-2008, 02:28 PM
This superFil is it a mix that I have to mix up for each application, or do i just spoon it out of the tub, and apply? Will paint be affected by the patch? The point that I am filling I am afraid will tin can and pop the SuperFil, "or any thing else out of the dent" is this some thing to worry about?
The dent is smaller than a 50 cent peice but looks like hellzz. I know zip about body work. What is an anchor pattern? What is epoxy resin? How do i mix it?
I appreciate yall's help think you I will post pictures as soon as I have time
Our Kit log
Old 09-25-2008, 04:17 PM
Geico266's Avatar
Geico266 Geico266 is offline
Sonny, Dude, relax man, have a brew, put your feet up and take a deep breath, smoke em if you got em. I know of very few builders that have not put a dent in the skins here or there. If I were you, knowing what I know, I would have another beer and look forward to the next build project. Worry about the dents, dings, & imperfections, right before you paint.
http://www.aircraftspruce.com/catalo...s/superfil.php
If you have to buy the 3 gallon size you might be making too many dents though.
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
Old 09-25-2008, 07:01 PM
airguy's Avatar
airguy airguy is offline
I put several dents in my tail, you'll get over it. Put it aside and build on. By the time you're ready to actually do something about it, you'll have done far worse than this and it will seem trivial, as will the fix for the dents.
Filler and paint hides dents on almost every flying airplane somewhere.
Old 09-25-2008, 08:53 PM
cwreeves cwreeves is offline
Thumbs up Dent
Sonny,
I recommend a good epoxy like AeroPoxy which is mixed 3 to 1 by volumn. You won't need special pumps or a scale. Acft spruce sells a qt kit. You'll need micro-balloons which are mixed into the epoxy. The mixture should be the consistany of sour cream or a little stiffer. Sand the area at least twice the size of the dent. Squeegee on with a plastic bondo spreader from local auto parts store. Let dry over night and sand smooth. It'll feather nicely. I'd use an orbital sander. Any filler you apply will cause the paint to flash, but this is remedied by several coats of primer. Hope this helps.
Charlie
Old 09-25-2008, 09:14 PM
rv4dude rv4dude is offline
Default Join the Club!
We all have done it. I use the 4 B's...take a Break, grab a Beer, go to Bed and the next day use the Bondo! And yes, there are better products to use other than the ol' polyester bondo. Just follow the suggestions stated above. More than likely you are okay, as long as there are no creases or cracks...you will be good. I was working in a very small shop on my -4 and my bagage sheet metal fell off a shelf and sliced the trailing edge of my elevator...the one WITH the trim tab. That one made me wiz my jeans. I had to modify the last "B" to "grab the checkBook."
Old 09-25-2008, 11:12 PM
I like the sound of that.
Originally Posted by cwreeves View Post
Sonny,
Charlie
I will put this one in my archive! Thank you.
Originally Posted by rv4dude View Post
We all have done it. I use the 4 B's...take a Break, grab a Beer, go to Bed and the next day use the Bondo! ."
4 B's I like that. Thanks for the info and support. Sorry to hear about your elevator . . . ouch
Our Kit log
Old 09-26-2008, 01:50 AM
Webb's Avatar
Webb Webb is offline
Default Inhale
First of all, it's an airplane. Nobody can see a little dent in the tail at 200mph. If is isn't a manditory repair, most little whoops are corrected and can't be found later. Go have a beer.
The Superfil that Geico266 mentions is outstanding. The small kit will last you your entire airplane and you will still have almost all of it left over. Mix up some the size of a gumball and away you go. Go have a beer.
I like the 4 B's. I might make it 5 since I might want 2 beers.
Suggestion - Learn how to post a picture and then you have a couple thousand building experts that can really help. It also will give you a 10 minute breather when you need it most. I can't tell you how many times I was trying to figure something out, came inside from the shop, got an anwer and started fresh again after a short interruption.
Happy building. What seems major now will seem minor later on.
Webb Willmott
Jackson, MS
N32WW
