09-24-2008, 11:03 PM
Fuel tank suction tube
Hi all. I ordered and received a standard fuel suction tube for installation in my left fuel tank (RV-8). When I attach it, it sits about 1/2 inch up off the bottom of the tank.
One thought is to bend it down slightly to get it to lie flat on the bottom so as to be able to get all the fuel available from that tank. The other option is to leave it alone and be satisfied with "unusable" fuel that might be contaminated with water.
What does everyone else do?
Jeff
-8 wings, finishing up
-8 QB Fuse just arrived!!!
09-25-2008, 12:40 AM
Both ideas have merit.
Perhaps leaving it up is more conservative, however I vote to bend it down.
09-25-2008, 06:39 AM
Bend it down!
The drain is there to get rid of contaminates and water.
Fuel below the pickup is useless.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
09-25-2008, 08:15 AM
And don't forget to tie it on...  Really, I would need to get out of the plane, stretch and *@!$ long before my tanks hit this point of no return.
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
09-25-2008, 09:49 AM
By tie it on, are you referring to the service bulletin that calls for safetying the attach nut , so the whole tube doesn't fall off? Got that one covered.
...except how does one go about drilling a hole at an angle in this nut so as to be able to run safety wire through there?
Jeff
09-25-2008, 10:05 AM
Clamped mine in a hold block and used a drill press...
Reiley
VAF# 671
Friend of the RV-1
09-25-2008, 02:08 PM
or a dab of proseal across the nut & fitting after verifying that it's torqued correctly...
