09-24-2008, 09:06 AM
Paint booth extractor fan
Hi Guys,
Does anyone know of a suitable fan to use as a paint booth extractor fan? Im rebuilding my paint shop and need a bigger fan.
Many thanx,
Simon
Simon Hitchen
Port Perry, ON, Canada
7 Tip Up, Titan XIO-360, Dual P-Mags, Airflow Performance matched Injectors, Sensenich FP Prop, Dynon Skyview, GTR-200, GTX-327
FLYING!
09-24-2008, 09:23 AM
simon,
for a small roll your own room, i used two gable fans and louvers from lowes. they move about 3600 feet of air each. they clear the 13'x20' room quickly. they are easy to mount and come with a temp/humidistat controller that i removed. the louvers however will stick after a while due to the paint being sticky.
William Weesner/ still kicking.
09-24-2008, 09:27 AM
There always seems to be a lot of discussion over the need to use a purpose built, non-sparking fan. I've painted several cars, constructing my own booth from pvc pipe and plastic. To avoid the expense and availability of a non-sparking fan, and the issue of a posssible explosion, I've always used standard box fans, but installed them to blow into the enclosure instead of out. A simple square slit on three sides of the poly serves as an exit flap and blows open from the air forced into the enclosure from the box fan. Tape an air conditioning filter to the suction side and then tape the discharge of the fan to the enclosure and start painting.
Tim Ribble
Virginia Beach
RV-6A (only took 13 years to build  )
N621TR In unrestricted operation
09-24-2008, 09:33 AM
Super Moderator
I've painted using 2 of the 20" box fans from WalMart. I buy the furnace filters by the carton from Lowes/Home Depot. I set the fans up to blow OUT, and use filters on the opposite ends of the booth for inlet air, and also place filters over the fans. The fans hold the filters just by suction. In a typical paint job I will go through about 30-40 filters. The inlet ones usually don't need replacing, but the ones on the fans get replaced quite frequently. I'm sure it doesn't meet OSHA standards, but it hasn't blown up yet. I use Dupont products (imron and Vari prime).
Vic
 Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES
Kitplanes "Unairworthy" monthly feature
EAA Sport Aviation "Checkpoints" column
EAA Homebuilt Council Chair/member EAA BOD
Author "Pre-Buy Guide for Amateur-Built Aircraft"
www.Baselegaviation.com
09-24-2008, 02:49 PM
I've used a Lowes gable fan on the outlet, painting with Poly Fiber products for fabric. Most of those are high VOC (lots of MEK and the like) and I put lots of overspray in the air with an old Binks #7. Obviously no explosion (I'm still here), but heavy overspray will gum the fan and motor bad enough to kill it due to overheat. So, a catch filter before the fan is a good idea.
The new shop got two Dayton explosion proof fans and catch filter boxes as a permanent installation. The boxes are welded from 1/2 steel angle. Each holds (6) 20x25 and (2) 20x20 filters, just the cheap long-strand variety for a home furnace inlet. With that much area you can spray a long time without loss of airflow.
Dan Horton
RV-8 SS
Barrett IO-390
09-24-2008, 08:56 PM
Why not an old furnace blower--centrifugal fan with the motor mounted outside the airstream? An HVAC guy told me that they get them quite often when they replace furnaces.
Richard Scott
RV-9A Fuselage
1941 Interstate Cadet
09-24-2008, 09:34 PM
Fan
I used a Home Depot 36" round fan for my temp paint booth. I don't think it's explosion proof but I never had any issues with it. Put a filter over it a you're good to go. I could never put it on high because it would suck the plastic right off the walls. I had eight 20"X20" filters on one end and the fan on the other. It worked very well and would clear the booth in a minute.
Aden Rich
Never met an airplane I didn't like!
09-25-2008, 07:32 AM
guess i should have done that before now.
09-25-2008, 07:34 AM
We used a portable car cover from pep boys, with the side curtin, and a {Heat Buster} fan from sam's, total set up was $400..., if we could attache pictures i would show it but . . .
Reason: who cares. .
09-25-2008, 02:18 PM
I've never understood the exhaust vs pressurize issue, except that pressurizing might create a stronger stream of air in front of the fan.
If the box is pressurized, a filter can be placed before the fan & trap all the trash being sucked in. If the fan exhausts the air, pressure in the box is lowered so air (& trash) can enter at any air leak in the box, not just through the filter.
What am I missing?
Charlie
