Depending on your density
altitude and drag on the airframe that is not that far out of line. I have the blended airfoil prop and I only see about 206-208 MPH true airspeed full throttle and 2700 RPM at 8000 DA. If I go down low to 500 DA in smooth air at full throttle and 2700 RPM I will see about 212-214 MPH true airspeed. With a fixed pitch prop you probably can't run full throttle down low due to overspeed, so you can't get a top speed because you aren't producing full HP from the engine.
Rusty "Rooster" Williams
N357RV RV-7A Tip Up (flying and Painted!) - 1560+ hrs.
Superior XP-360, carbureted, Hartzell 74" Blended Airfoil Prop
Grand Prairie, TX
KGPM
