Old 09-22-2008, 05:12 PM
David_Nelson's Avatar
David_Nelson David_Nelson is offline
Default Trimming/shaping UHMW blocks
Hey Guys and Gals,
What's the best way to neatly trim and shape UHMW blocks? I've tried the scotch-bright wheel on low RPM but that does not seem to do it (maybe for final polishing).
I'm making the tip-up canopy latch guides and I've got the basic block made. Now I want to shape it into something that looks somewhat aesthetically pleasing to the eye.
/\/elson
RV-7A Tip-Up
NW Austin, TX
Old 09-22-2008, 05:16 PM
hydroguy2's Avatar
I use a bandsaw followed by an italian milling machine. here's a pic:
Old 09-22-2008, 05:17 PM
Mel's Avatar
Mel Mel is offline
Shape with a belt sander and then scrape the corners with an Exacto knife.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 09-22-2008, 09:14 PM
Greg Arehart's Avatar
Or get yourself a piece of delrin plastic that is easier to work.
greg
Greg Arehart
N 7965A
Old 09-22-2008, 10:17 PM
hgerhardt's Avatar
hgerhardt hgerhardt is offline
That's a Vixen file, and it works the best for the UHMW blocks. It's also important that the file is new and sharp. If it's been used much on metal, go buy a new one. You need to apply heavy pressure and go slowly. The block needs to be in a vise so you can apply enough pressure. Also, hold the file in a 60 deg angle to the block and slide the file lengthwise with the block so that the teeth slice into the plastic. This is not the same as holding the file 60 deg to the work and going back and forth. I'm talking move the file sideways. This takes some practice to master, but it will remove stock quickly and leave a nice finish. This technique works well on metal, too.
Heinrich Gerhardt
RV-6, flying
Old 09-22-2008, 10:52 PM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
A bench grinder with a coarse stone is about 10X faster than a file.
Ross Farnham, Calgary, Alberta
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, Shorai- RV6A C-GVZX flying from CYBW since 2003- 441.0 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://www.sdsefi.com/aircraft.html
http://sdsefi.com/cpi2.htm
