Old 09-22-2008, 05:07 PM
erich weaver's Avatar
Default Why are factory set rivets better?
For those that used the Quickbuild option, if you do an honest, close comparison of the factory set flush rivets with rivets that you set yourself, dont you find that the factory ones look superior overall? There's nothing really wrong with mine - but they generally are just not as perfectly flush as the factory ones. I did a quick look around the airport at other RVs and it seems to be the case for others as well.
Im having my -7A painted now, and man, the paint goes over those factory rivets on the wing really nicely. You can still see that the rivet is there, but the paint perfectly bridges the skin-to-rivet contact. Not always the case for the rivets I set, although again, its acceptable, and seems to be similar to most other RVs I see.
I know that the factory guys have set far more rivets than I ever will, but can someone quantify the reasons why theirs are so darn consistently perfect? I think I would have a very hard time matching their quality no matter how careful I was.
erich
Old 09-22-2008, 05:10 PM
asav8tor asav8tor is offline
rivet tape
Old 09-22-2008, 05:32 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
If all you did all day was set rivets, you'd probably set them better too. It's much easier to be consistent when you have time to get in a rhythm.
However, that said, I was surprised when I went to Oshkosh 2006, looked at the RV7 quickbuild fuse that was there on display and returned thinking quite the opposite about the shopheads... that my SB riveting quality was probably not much, if any, worse, and I don't think that I'm any better than average at riveting. To be sure, I've got my share of bungled rivets, but so did the QB.
One thing that will really help the "flushness" of your rivets is either (1) backriveting or (2) using a solid rivet set. The swivel version will prevent big dents if yoiu get careless, but it does not as efficiently transfer the pounding of the rivet gun, thus providing more time for the rivet to get pushed out by the bucking bar before it sets.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 09-22-2008, 05:34 PM
robertahegy's Avatar
robertahegy robertahegy is offline
Moderator/Tech Counselor
My rivets were set every bit a well as any in my QB kit done by the factory. Properly prepped, dimpled and set there should be no difference. It just takes practice, patience and caring. My riveting experience was limited to what I learned in the RV assembly seminar and what I did on the plane I built.
Roberta
Roberta Hegy
Built/Flew an RV-7A
Air Troy Estates, East Troy, WI
Ford Expedition and TRICE "Q"
Built Glen L "ZIP" Classic Outboard Runabout and Super Spartan Hydroplane
Glen L Torpedo
Old 09-22-2008, 05:48 PM
DarylT's Avatar
DarylT DarylT is offline
I can promise you they dont use rivet tape on the Quickbuilds......
Its just a matter of doing all day everyday.
Daryl Tolliver
VAF 1086
Yes: I paid my =VAF= membership dues for 2020
RV-7A - N754RV: Status - Pink Slip is In! First Flight 8/23/12 - My First Flight 9/24/12!
Home from GloCustom for Paint! 3/16/13
957 hours and climbing
7th Condition Inspection complete 10/31/2019
Superior XP IO360 (180 HP), Hartzell Blended Airfoil, AF-5400 EFIS panel, Garmin Aera 660, TruTrak Vizion 385 AutoPilot, Dual Pmags
Houston, TX
Track: SPOT
Weiser Airpark (EYQ)
http://www.rv7a-factory.com
Old 09-22-2008, 06:01 PM
Geico266's Avatar
Geico266 Geico266 is offline
Bingo. 10-12 hours a day.
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
Old 09-22-2008, 06:09 PM
the_other_dougreeves the_other_dougreeves is offline
Originally Posted by alpinelakespilot2000 View Post
If all you did all day was set rivets.....
... you'd be crazy enough to build your own airplane.
TODR
Doug "The Other Doug Reeves" Reeves
CTSW N621CT - SOLD but not forgotten
Home Bases LBX, BZN
Old 09-22-2008, 06:19 PM
noelf noelf is offline
I believe that I have mastered the rivet process as well as anyone. But one of the items I have come to accept is it is important to have a "rivet buddy" who also shares your desire for the "perfect" rivet set. When I need a helper, I turn to my one-and-only rivet buddy. It truly does make a difference, and we do get consistent, excellent results.
I have had folks volunteer to help with driving or bucking, I just don't want to teach them on my ac. I am very willing to help them on their own projects...
Old 09-22-2008, 07:36 PM
EastTXHills's Avatar
EastTXHills EastTXHills is offline
I think they do, I used denatured alcohol to remove the slight residue outline of tape on the wing skin rivet lines.
Old 09-22-2008, 07:51 PM
L.Adamson's Avatar
L.Adamson L.Adamson is offline
Scotch #811 removable tape in the blue box. Available at office supply stores. Perfect wing and fuselage rivets...........every time!
L.Adamson -- RV6A
