Well, I WAS fortunate to be able to do it over again and my initial thinking was along the same lines as yours. What I did differently:
#1. The single greatest aid to an easier assembly process was taking the time to cob together a fuselage rotisserie. Using it allowed much easier and far less physically tiring interior access. The ease and utility of a rotisserie naturally lends itself to suggestion number 2:
#2. Prewire everything and test as many circuits as possible before you move the project out to the airport. This includes the instrument panel, autopilot servos, strobes, lighting, pitot heat, ELT, headphone jacks, stick grips, etc. In my case, by the time I mated the wings, the bugs were worked out and only a few electrical hookups needed to be joined and the wiring was completely done.
#3. Complete all fiberglass work short of paint as you work through each kit including the intersection fairings of your choice. As I did the first time, consider attaching all the fiberglass tips...all of them with screws and nutplates. This will allow you the option to paint the individual tips later.
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
EAA Technical Counselor
